Special Order 8 (440) #802727
09/16/10 08:01 AM
09/16/10 08:01 AM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
My father owned a 67 New Yorker with the VIN code that translated to 'Special Order 8'. The book showed two possible engines - the standard 440 and the Special Order 8. He used to tell us that it meant it had the 'police' engine.
But, in later years it became obvious the engine was a normal 440 in every way - log manifolds, no windage tray, single snorkel air cleaner, etc.
The only thing I could find that was different was it had a Holley rather than a Carter.
So, what does Special Order 8 actually mean?
Re: Special Order 8 (440) [Re: GregCon] #802728
09/16/10 09:19 AM
09/16/10 09:19 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I ran into something similar about 4 years ago trying to decode a 65 Dodge 880 sedan I bought. It had a certified speedo, a special brass ID tag on the doorjamb (I presume installed by a fleet customer) and had special engine codes on the fendertag.
The car only had a 383 2-barrel, which was standard in the 880, and it appeared to be original (or accurate for the car, at least).
I never found out any further info on that engine code.
The 350hp 440 in 67-68-ish generally had a Holley carb.
Re: Special Order 8 (440) [Re: GregCon] #802729
09/16/10 11:13 AM
09/16/10 11:13 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
what was the vin code for it? dan
Re: Special Order 8 (440) [Re: ph23vo] #802730
09/16/10 02:18 PM
09/16/10 02:18 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I believe the Special Order code for '67 was "K".
Re: Special Order 8 (440) [Re: Commando1] #802731
09/16/10 02:42 PM
09/16/10 02:42 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
K is the code for the standard 440-4 low power.
M would be the special order V8.
Maybe the original poster was looking at a '66 decode where K would indicate a special order V8. By 67, K just means the standard 440.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Special Order 8 (440) [Re: 69CoronetRT] #802732
09/16/10 05:58 PM
09/16/10 05:58 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
66 K was special v-8 67 M was special v-8 so is it an M code 67? that would be too cool.. i bet its a K code though just run of the mill regular stuff dan
Re: Special Order 8 (440) [Re: ph23vo] #802733
09/16/10 08:22 PM
09/16/10 08:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
could have been a typo , wouldn't be the first time , K and M are one over the other on a keyboard ????
Re: Special Order 8 (440) [Re: JohnRR] #802734
09/16/10 10:28 PM
09/16/10 10:28 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
I don't recall the letter any longer but believe me, we checked it many times and it was Special Order 8.
Re: Special Order 8 (440) [Re: GregCon] #802735
09/16/10 10:53 PM
09/16/10 10:53 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
remember the service manuals were wrong in 66-7 if that where you got your info... dan
Re: Special Order 8 (440) [Re: ph23vo] #802736
09/17/10 08:58 AM
09/17/10 08:58 AM
Commando1 Offline
Commando1  Offline
Allpar:
