old mopar regulator #802115
09/15/10 04:59 PM
09/15/10 04:59 PM
btomasko Offline OP
btomasko  Offline OP
Just how good is the electronic voltage regulator, the old one that there now converting to electronic, need opinions thanks
Re: old mopar regulator [Re: btomasko] #802116
09/15/10 08:29 PM
09/15/10 08:29 PM
btomasko Offline OP
btomasko  Offline OP
BTT
Re: old mopar regulator [Re: btomasko] #802117
09/15/10 08:44 PM
09/15/10 08:44 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
no idea what u asked
Re: old mopar regulator [Re: btomasko] #802118
09/15/10 08:52 PM
09/15/10 08:52 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The old pre 1970 single field mechanical regulators? They worked fine usually and were adjustable. I have one of those mp blue 13.5 volt substitutes, and haven't tried it. Most parts stores also have an electronic replacement in stock too, for the old points style reg. (69 and older)
Re: old mopar regulator [Re: buildanother] #802119
09/15/10 09:19 PM
09/15/10 09:19 PM
scratchnfotraction Offline
i would upgrade it to the newer solid state elect VR on it over the mech points type
best up grade I did to my 68 dart
still ran points too,till I swaped in the pertronix conversion,2nd best upgrade I did to it
Re: old mopar regulator [Re: scratchnfotraction] #802120
09/15/10 10:56 PM
09/15/10 10:56 PM
Parts houses have a wells vr706 if I am remembering the # correctly that is an electronic replacement for 69 back cars but is not identical to OE appearance and someone here sells (or used to have) new black ones that looked OE but is electronic on the inside for $25 to your doorstep (mrrandy was his handle or something close to that so if you see it that's the one) I'd check the parts for sale sections here if that is what you are after.
Re: old mopar regulator [Re: btomasko] #802121
09/16/10 12:26 AM
09/16/10 12:26 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
I use the electronic conversion regs. and no problems at all...constant volts. Bought mine at Autozone or Advance for a decent price.
Re: old mopar regulator [Re: 52savoy] #802122
09/16/10 09:56 AM
09/16/10 09:56 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And your cover from an original fit's.
Re: old mopar regulator [Re: 52savoy] #802123
09/16/10 11:18 AM
09/16/10 11:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The new replacements are the best thing since sliced bread.Have them on 3 cars.My kids 62 street driven has been on at least 10 years.Dump the old points one and get the direct replacement electronic one.I changed my 65 to a dual field years ago.If the new style had been avaliable Id have one of those on it.Best part is they just go right in with no changes.Rocky
Chrysler Firepower
