Putting in a gasket window. #801120
09/14/10 11:33 AM
09/14/10 11:33 AM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
Any tips for roping a gasket in? What size rope what to lube the gasket up with anything would be great thanks
Jason oh it's a 70 duster
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: Putting in a gasket window. [Re: haddixj] #801121
09/15/10 08:07 AM
09/15/10 08:07 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
You need to use a high quality Urethane sealer. After the gasket is installed, with urethane, around the metal just use a dish soap solution on the glass and some stiff plastic spoons(for the lack of another word)and slide it between the rubber and glass. After soap solution dries use the Urethane to seal the glass to the rubber.
Re: Putting in a gasket window. [Re: Mopar Grandpa] #801122
09/15/10 12:30 PM
09/15/10 12:30 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
Thanks for the tip so you don't use a small piece of rope?
Re: Putting in a gasket window. [Re: haddixj] #801123
09/15/10 12:37 PM
09/15/10 12:37 PM
pa.
dan9 Offline
dan9  Offline
pa.
I'd try to help you but i'm not sure if it is the same as a b-body. If it is i could offer some suggestions.
Re: Putting in a gasket window. [Re: haddixj] #801124
09/15/10 01:24 PM
09/15/10 01:24 PM
Sebring, Florida
Sebring, Florida
I didn't and didn't have any trouble installing the glass on my '68 Barracuda. Just start in one corner and work the plastic tool around the perimeter.
Re: Putting in a gasket window. [Re: Mopar Grandpa] #801125
09/15/10 03:59 PM
09/15/10 03:59 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
I think there about all the same. So bring on any help and thanks for the encouragement I am going to give it a shot this weekend
Re: Putting in a gasket window. [Re: haddixj] #801126
09/15/10 06:03 PM
09/15/10 06:03 PM
WI
RestoRick Offline
RestoRick  Offline
WI
You have to put the gasket on the pinchweld first...
then work the windshield into the gasket.
There's too much "meat" on the corners of the gasket to use the "pull the rope to the inside" method.
Rick
