Re & Re Water Pump Help !!!!!!!!!!
#800498
09/13/10 08:43 PM
09/13/10 08:43 PM
Posts: 1,951 Toronto Ontario
Butt Ugly
Toronto Ontario
Tore the Pump out of my small block, I take things apart real good, back together not so much. Is there a source where I can find some good exploded views of the brackets and such to re install the pump on a power steering car. Thanks, and to all the replies about my dip dip tube, I was able to yank the broken end out of the block with the pump off and ready to tap a new tube in. Thanks Again
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Re & Re Water Pump Help !!!!!!!!!!
[Re: Butt Ugly]
#800499
09/13/10 11:03 PM
09/13/10 11:03 PM
RapidRobert
I just added PS to the 80's 318 in a 65 Dart. There's a triangular bracket & the flat end w 2 holes, bolts to the 2 water pump/block holes on (1) the dr bottom and (2) the next wp hole right above it and the other end of the triangle bracket w 1 hole takes a bolt to support the PS pump assy. A 3rd bolt goes thru the long belt tension adjusting slot in the PS assy & goes into the wp/block at about 3 o'clock. EDIT use the right length bolts exp on the dr side as one too long can (& has) hit/cracked the #1 cyl wall (it's further forward). If you're mixing/matching bolts you want to have at least 1.25 times the bolt dia amt of actual thread engagement into the block threads themselves (plus a bit more, depends on the app) & you're set.
