4 speed ID #79996
06/26/08 10:49 AM
06/26/08 10:49 AM
Pennsylvania
proshiftcharger Offline OP
Pennsylvania
Members,
Can you help me ID this 4 speed?
Im trying foremost to determine what year the tranny is and with a little luck the model it came from originally.
Aluminum
18 spline
2801176 (numbers on left main case torwards front)
5 C95664 Z (side plate shifter linkage cover)
3410391 (tail shaft numbers)
dual shifter mounts plates on tail shaft.
thats all the info I have,
please advise,
thanks
Doug
Re: 4 speed ID [Re: proshiftcharger] #79997
06/26/08 10:55 AM
06/26/08 10:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
sounds like something that was pieced together , is it a crash box ?
is the tail alum or cast iron ? no STREET car came with an ALUM case , especially one with a dual shifter tailshaft , at least nothing i ever saw , if thats what you are thinking
Re: 4 speed ID [Re: JohnRR] #79998
06/26/08 11:45 AM
06/26/08 11:45 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's most likely a truck/van overdrive case with 18-spline internals, if it is, in fact, an 18-spline. Get the numbers stamped on the pad of the main case.
Re: 4 speed ID [Re: Jim_Lusk] #79999
06/26/08 12:00 PM
06/26/08 12:00 PM
Pennsylvania
Pennsylvania
Thanks for the quick replies...
I dont have any other stampings marked on the cases other than what I already listed.
As far as the tail shaft goes, yes it is aluminum as well. It could be a crash box but Im not certain.
It could very well be pieced together rather than "dedicated" to one year/model.
Based on what I gave you can you determine anything at all?
much appreciated,
Doug
Re: 4 speed ID [Re: proshiftcharger] #80000
06/26/08 12:06 PM
06/26/08 12:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
never seen an alum dual mount tail , the plot thickens ...
what are you wanting to do with it , buy , sell , price it , ????
do you have it in front of you persay ?
Re: 4 speed ID [Re: JohnRR] #80001
06/26/08 01:00 PM
06/26/08 01:00 PM
Pennsylvania
Pennsylvania
John...
Yeah its all aluminum, tail shaft included.
I dont have it in front of me right now but I do have access to it.
Can you explain the dual mounts on the tail shaft?
thanks,
Doug
Re: 4 speed ID [Re: JohnRR] #80002
06/26/08 01:10 PM
06/26/08 01:10 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I have a couple dual mt tails that are aluminum. One of them has been coated with a cast iron powder. Some one was "bending" the rules a long time ago.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 4 speed ID [Re: proshiftcharger] #80003
06/26/08 01:13 PM
06/26/08 01:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John...
thanks,
Doug
dual mount tail is a 70-74 B/E and later pickup/van
Re: 4 speed ID [Re: 64dodge572] #80004
06/26/08 01:14 PM
06/26/08 01:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
interesting , what would they have been used in , 70 up super stock car ?
Re: 4 speed ID [Re: JohnRR] #80005
06/26/08 06:35 PM
06/26/08 06:35 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
John...
thanks,
Doug
A-833 O.D. 4-speeds used in vans did come with dual pattern tail housings as John said, but I've only ever seen them with cast iron housings, not aluminum. FWIW, here's a pic of my '86 A-833:
Re: 4 speed ID [Re: proshiftcharger] #80006
06/27/08 10:13 PM
06/27/08 10:13 PM
Pennsylvania
Pennsylvania
Thanks for the replies, as always very educational.
Any thoughts/input on the series of numbers listed above?
thanks again,
Doug
Re: 4 speed ID [Re: proshiftcharger] #80007
06/30/08 11:04 AM
06/30/08 11:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks again,
Doug
yes they are casting numbers that are basicly USELESS in trying to identify a transmission ...
but since this is an all alum case trans ?????
Re: 4 speed ID [Re: JohnRR] #80008
06/30/08 11:39 AM
06/30/08 11:39 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
thanks again,
Doug
Here's a pic of the RH side of an aluminum main case:
See the raised pad that is machined smooth and stamped with some characters? Look at the pad on your main case and let us know what is stamped there. For reference, here's a stamped pad up close:
Re: 4 speed ID [Re: In_The_Pink] #80009
06/30/08 01:33 PM
06/30/08 01:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks again,
Doug
the interesting number is the 2801176 (numbers on left main case torwards front)
whats on the trans you have ? i just threw in my scrap pile an alum OD trans case or i would be able to look at that now instead of later .
that number he put up is a part number for something made in roughly 67 or 68 , thats the confusing part .
