Re: 4 speed ID
[Re: JohnRR]
#80002
06/26/08 01:10 PM
06/26/08 01:10 PM
Posts: 4,285 Ohio
64dodge572
Ohio
never seen an alum dual mount tail , the plot thickens ...
what are you wanting to do with it , buy , sell , price it , ????
do you have it in front of you persay ?
I have a couple dual mt tails that are aluminum. One of them has been coated with a cast iron powder. Some one was "bending" the rules a long time ago.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
Re: 4 speed ID
[Re: proshiftcharger]
#80003
06/26/08 01:13 PM
06/26/08 01:13 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
John... Yeah its all aluminum, tail shaft included. I dont have it in front of me right now but I do have access to it.
Can you explain the dual mounts on the tail shaft?
thanks, Doug
dual mount tail is a 70-74 B/E and later pickup/van
Re: 4 speed ID
[Re: 64dodge572]
#80004
06/26/08 01:14 PM
06/26/08 01:14 PM
JohnRR
U.S.S.A.
interesting , what would they have been used in , 70 up super stock car ?
Re: 4 speed ID
[Re: JohnRR]
#80005
06/26/08 06:35 PM
06/26/08 06:35 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
thanks, Doug
A-833 O.D. 4-speeds used in vans did come with dual pattern tail housings as John said, but I've only ever seen them with cast iron housings, not aluminum. FWIW, here's a pic of my '86 A-833:
Re: 4 speed ID
#80006
06/27/08 10:13 PM
06/27/08 10:13 PM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
2801176 (numbers on left main case torwards front) 5 C95664 Z (side plate shifter linkage cover) 3410391 (tail shaft numbers)
Thanks for the replies, as always very educational.
Any thoughts/input on the series of numbers listed above?
thanks again, Doug
Re: 4 speed ID
#80007
06/30/08 11:04 AM
06/30/08 11:04 AM
JohnRR
U.S.S.A.
thanks again, Doug
yes they are casting numbers that are basicly USELESS in trying to identify a transmission ...
but since this is an all alum case trans ?????
Re: 4 speed ID
[Re: JohnRR]
#80008
06/30/08 11:39 AM
06/30/08 11:39 AM
In_The_Pink
Milwaukee, WI
thanks again, Doug
Here's a pic of the RH side of an aluminum main case:
See the raised pad that is machined smooth and stamped with some characters? Look at the pad on your main case and let us know what is stamped there. For reference, here's a stamped pad up close:
