Re: brake problem/question
[Re: 1969RR]
#799539
09/12/10 09:52 PM
09/12/10 09:52 PM
Posts: 221 Illinois
Tinman761
Illinois
well over the winter, i replaced my axle bearings with green bearings and also my open to a suregrip, i also decided to replace the shoes and hardware,and wheel cylinders and top it off with prestone dot 3 synthetic from auto zone. I also asked if it was compatibleand they said yes. so i take it for a ride about 30 miles everythings ok. next day i take it to get exhaust put on and about 20 miles down the road smoke is pouring from the rear wheels. i get it home after the exhaust,pulled the wheels and its a mess, and wheel cylinders are seeping fluid. I replace the wheel cylinders and hardware and shoes, cut the drums, and topped off the fluid with napa brake fluid. go out today, get about 20 miles and can smell the linings smoking again. come home and on the way home it seems they are really dragging. take it apart again and fluid is seeping from the wheel cylinders, so that is why im seeking advice, Joe
[Re: Tinman761]
#799542
09/12/10 10:18 PM
09/12/10 10:18 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
Silicone fluid is DOT 5 , and can not be mixed with other fluids. Synthetic fluid is something different, and I would just follow the instructions on the bottle about mixing. I think your problem is caused by the brakes dragging, due to maybe the master cylinder rod adjusted a little long, or shoes not adjusted right or ? But not from mixing fluid if you did not involve Dot 5 Silicone.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: 1969RR]
#799543
09/12/10 10:21 PM
09/12/10 10:21 PM
Posts: 221 Illinois
Tinman761
Illinois
I appreciate the help. I had a feeling i shouldnt have mixed those, and i also think it might be the master. Am i correct in my thinking, but when you pull back the boots on the wheel cylinders, there should not be any fluid seeping from the piston. The pistons on the passengers side wheel cyl. are also hard to move in and out. Im trying to keep the car original, do you know of any sources that may have an oe master? Joe I forgot to add they are manual brakes
[Re: Tinman761]
#799544
09/12/10 10:31 PM
09/12/10 10:31 PM
RapidRobert
The prob ain't happening that fast from fluid incompatibility. I'm thinking the OE wh cyls are worn out of spec (dia/pitting) and are leaking from that. Never heard of excessive psi causing them to leak ![](/ubbthreads/images/graemlins/Twocents.gif) PS are you using the correct size rebuild kits? Wouldn't think a person would not notice that (difference)in pistons/cups but just kicking out ideas to stimulate you
[Re: Tinman761]
#799546
09/12/10 10:46 PM
09/12/10 10:46 PM
RapidRobert
Alright not worn OE cyls and w no prob until the rear brake work was done either there's a prob in the cyls or the fluid . Not sure on flushing it but I'd be inclined to do so rather than tossing any more parts at it which you have done to no avail. Maybe I'm wrong & mixing the fluid (types) CAN screw it up that fast.
