manifolds #799331
09/12/10 03:59 PM
09/12/10 03:59 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
what are these off of?
Re: manifolds [Re: FC7 cuda] #799332
09/12/10 04:11 PM
09/12/10 04:11 PM
Under My Car
Mopar_Country Offline
Under My Car
I wouldn't swear to it, but they kinda look like 340 manifolds. Got a casting number?
Re: manifolds [Re: Mopar_Country] #799333
09/12/10 05:15 PM
09/12/10 05:15 PM
california
moparmanof85 Offline
california
looks like small block. thinking 340 as well
Re: manifolds [Re: moparmanof85] #799334
09/12/10 06:16 PM
09/12/10 06:16 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
If they are off a 340, it's not the early version.
Probably '72-up, that's when the ball flange for the head pipe started.
Any casting numbers on them?
Re: manifolds [Re: B5 Bee] #799335
09/12/10 06:45 PM
09/12/10 06:45 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
ball flange?
Re: manifolds [Re: FC7 cuda] #799336
09/12/10 06:53 PM
09/12/10 06:53 PM
Under My Car
Under My Car
He is referring to the flange where the pipe bolts on. If you notice it is half rounded. The pipe would be flared to mate to it. Post the casting numbers to be sure of application.
Re: manifolds [Re: Mopar_Country] #799337
09/12/10 07:47 PM
09/12/10 07:47 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
318 with the small outlets. Should have smaller exhaust ports too. There are some early A-body 273's that are like that too, but they don't have provisions for heat stove (if that heat stove is really for those). Probably not same outlet angle/placement too as early type too.
Re: manifolds [Re: autoxcuda] #799338
09/12/10 07:55 PM
09/12/10 07:55 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
here is a pic of my 68 318 manifold. 67 cast date.
Came out of a 68 Fury.
As you can see the ball flange was in use before 72.
I agree the drivers side is most likely for an early a body. Clearance issues would be the reason for the odd exit and the up swept ports.
