Re: pilot bearing???
[Re: Cudajon]
#798902
09/12/10 04:00 PM
09/12/10 04:00 PM
DaytonaTurbo
Manitoba, Canada
Do some more checking, the T/O bearing Keisler uses fits in the torque converter hole on the flywheel.
Also, all the 90's dodge trucks with a manual transmission used the bearing that sits in the torq converter register on the crank. It's common to use this bearing on 440's and such with cast cranks that don't always have the pilot hole drilled. Perhaps you can find a bearing that will work. If not I would have your input shaft turned down on a lathe to regular mopar size so you can use the 90's pilot bearing or a stock type pilot bushing.
[Re: moparmanof85]
#798905
09/12/10 08:09 PM
09/12/10 08:09 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
my other option is to use a standard bearing and hone down the input shaft. what would you do?
that is a good permanent solution and you wouldn't have to get into any custom stuff every time you change the pilot bearing/bushing. Take the trans apart and cut down the input tip diameter to stock mopar size.
