Correct Black Paint For Heater and A/C Box #798825
09/11/10 05:30 PM
09/11/10 05:30 PM
MD
Moparlang Offline OP
MD
Hello everyone, checking to see if anyone has the correct color or formula for the A/C and heater box black. It's used on the vent doors, evap box, etc. Appears to be a semi-gloss black, but not semi-gloss glossy. Thanks!!
The "mailman's son" Bad mailman!!
Re: Correct Black Paint For Heater and A/C Box [Re: Moparlang] #798826
09/11/10 05:34 PM
09/11/10 05:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No such animal... The heater box wasn't painted, the raw material color showed...
Re: Correct Black Paint For Heater and A/C Box [Re: 1_WILD_RT] #798827
09/11/10 08:05 PM
09/11/10 08:05 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup...Mine before washing,
After pressure washing,
Got new stuff inside,
Re: Correct Black Paint For Heater and A/C Box [Re: Moparlang] #798828
09/11/10 11:50 PM
09/11/10 11:50 PM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
The steel parts that are showing on my 1969 A/C box when looking under the dash are gloss black. The gloss looks the same as the interior paint used on the doors and upper frames i.m.o.
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: Correct Black Paint For Heater and A/C Box [Re: Challenger 1] #798829
09/12/10 01:27 PM
09/12/10 01:27 PM
None
71rm23 Offline
71rm23  Offline
None
Did the same thing to my box as Challenger1. Turned out great!
Re: Correct Black Paint For Heater and A/C Box [Re: 71rm23] #798830
09/12/10 01:52 PM
09/12/10 01:52 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Enjoy
Re: Correct Black Paint For Heater and A/C Box [Re: JulesdaWiperman] #798831
09/12/10 01:53 PM
09/12/10 01:53 PM
super gas
super gas
no paint
Re: Correct Black Paint For Heater and A/C Box [Re: JulesdaWiperman] #798832
09/12/10 01:54 PM
09/12/10 01:54 PM
super gas
super gas
Re: Correct Black Paint For Heater and A/C Box [Re: JulesdaWiperman] #798833
09/12/10 01:55 PM
09/12/10 01:55 PM
super gas
super gas
How do you post all the pictures on one response please?
Re: Correct Black Paint For Heater and A/C Box [Re: JulesdaWiperman] #798834
09/12/10 04:27 PM
09/12/10 04:27 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You post one attachment like you always do. Then you open that attachment and it will pop up in another window. Copy that URL code. For instance this is the code for your first picture: https://board.moparts.org/ubbthreads/upload2/6191898-ACHeaterBox002.jpg
Then edit your post and hit the Instant UBB Code for "Image". Then paste in your URL code for that previous attachment. Then go to the make attachment screen again and attach your 2nd picture. You should see your first picture in the edit attachment screen. Repeat as neccessary. The last picture you want should not have the [image][/image] code on your post, it should just be a regular attachment.
Here are your 3 pictures URL's stuck between [image][/image] code. If you just remmeber the code [image][/image] you don't have to hit that Instant UBB Code button to the right of your edit box and it will save you some time.
Re: Correct Black Paint For Heater and A/C Box [Re: autoxcuda] #798835
09/12/10 06:14 PM
09/12/10 06:14 PM
super gas
super gas
Thank you very much.
Re: Correct Black Paint For Heater and A/C Box [Re: JulesdaWiperman] #798836
09/12/10 06:22 PM
09/12/10 06:22 PM
Cincinnati, Ohio
Cincinnati, Ohio
Or you can use Photobucket like I do.
Re: Correct Black Paint For Heater and A/C Box [Re: JulesdaWiperman] #798837
09/12/10 07:36 PM
09/12/10 07:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I suggust going back to your first post and trying it out to get some practice with it. It's takes some time to get used to. Can't hurt anything.
Re: Correct Black Paint For Heater and A/C Box [Re: autoxcuda] #798838
09/12/10 08:57 PM
09/12/10 08:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I picked up an un-restored non-a/c heater box for a 1967 GTX and the metalplate on the front is a dull semi-gloss black, definitly not either flat or gloss black
plastic housings are unpainted
Re: Correct Black Paint For Heater and A/C Box [Re: gtx6970] #798839
09/12/10 11:02 PM
09/12/10 11:02 PM
MD
MD
OK, I didn't think I would have say this, but I'm talking about the metal parts that are painted black. I know the plastic/fiber whatever parts aren't painted, this is obvious(c'mon guys). Oh, by the way, there is such an animal, it's called the metal heater and A/C box parts. SO, any help would be appreciated.
Re: Correct Black Paint For Heater and A/C Box [Re: gtx6970] #798840
09/13/10 10:53 AM
09/13/10 10:53 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
He just told you and
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Correct Black Paint For Heater and A/C Box [Re: Moparlang] #798841
09/14/10 12:50 AM
09/14/10 12:50 AM
WORKER_BEE Offline
WORKER_BEE  Offline
Moparlang
I think you're going to have to be more specific on what you're working on, like year and model. What I said on my first post was for a nice clean unrestored '69 B body A/C box. Hope this helps!
1969 Charger R/T SE
1968 Crown Coupe
