dana 4.56 to 4.10 question #798519
09/11/10 10:35 AM
09/11/10 10:35 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Do i need to change the spool, or can i get away with using a spacer.
Dodge Dart 440 around 600 hp.
Mick
Re: dana 4.56 to 4.10 question [Re: deaks] #798520
09/11/10 05:28 PM
09/11/10 05:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Change the spool!!
Nautilus Racing-
Re: dana 4.56 to 4.10 question [Re: Chris2581] #798521
09/11/10 06:07 PM
09/11/10 06:07 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
The spool is a great expense i could do without, why is a spacer not a viable option.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: dana 4.56 to 4.10 question [Re: deaks] #798522
09/11/10 06:28 PM
09/11/10 06:28 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You want to go from a 4.56 to a 4.10?
No can do, if the spool you currently have doesn't have a spacer for the 4.56 gears. The 4.10 requires a different series spool/carrier than a 4.56 gear set.
Unless you get the special 4.10 gear set that is designed for the 4.56 carrier. It's got a thin ring gear.
Re: dana 4.56 to 4.10 question [Re: RobX4406] #798523
09/11/10 08:14 PM
09/11/10 08:14 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Yes, They used to make a 4.10 gear set with a thin ring gear to use on the 4.56 carrier.
Sheldon
Re: dana 4.56 to 4.10 question [Re: RUNCHARGER] #798524
09/11/10 09:16 PM
09/11/10 09:16 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We went from 4.56's to 4.10's with a spool and did not need a spacer. Richmond makes a gear set that will fit (69-0052-1). Motor is alot happier and ET's were the same.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: dana 4.56 to 4.10 question [Re: Dads426] #798525
09/13/10 05:19 AM
09/13/10 05:19 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Thanks for the replies.
Last year i blew the motor, so i dont want this motor revving to the moon for longevity reasons.
Mick
best 60ft 1.36
Re: dana 4.56 to 4.10 question [Re: deaks] #798526
09/14/10 05:05 AM
09/14/10 05:05 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
What was the drop in rpm and what tyre size do you run.
How do i identify which axle carrier i have and is the thin ring gear weaker than a thicker one.
Mick
Re: dana 4.56 to 4.10 question [Re: deaks] #798527
09/14/10 11:08 AM
09/14/10 11:08 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unless the rear was built with a ring gear spacer, you have a 5 series carrier.
5 series 4.10 gears are not weaker than 3 series gears.
