Re: Pro's and Con's of the small block 587 casting heads?
[Re: 72swgnr]
#798275
09/10/10 10:47 PM
09/10/10 10:47 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
The only ones that are gonna make any differance in power are gonna be magnums, waaaaaaay better chambers, better ex ports and better ex ports, milled valve cover rails, 10 valve cover bolts, no water on ex manifold bolts... but beside the magnum no other 340-360 head will make significantly more power. For low end TQ the closed chamber 273 and 318 heads are better if built to take advantage of the quench but they will not make the top end power of the 340-360 heads.
[Re: HotRodDave]
#798280
09/11/10 11:46 AM
09/11/10 11:46 AM
Posts: 382 Roseville MN
72swgnr
Roseville MN
Thanks guys. I was told that I would have trouble with pinging at 10.5-1 compression using this head and KB 190 pistons.
That depends on cam and a few other things. Not a sure thing like a magnum with good quench.
cam specs are:
Intake Duration at 050 inch Lift 251 Exhaust Duration at 050 inch Lift 257 Duration at 050 inch Lift 251 int./257 exh. Advertised Intake Duration 295 Advertised Exhaust Duration 307 Advertised Duration 295 int./307 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.564 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.564 in. Valve Lift with Factory Rocker Arm Ratio 0.564 int./0.564 exh. Lobe Separation (degrees) 110
Comp recomends 10.1 compression with this cam. So hopefully we can get the compression between 10.1-10.5-1 so I can run 91-92 octane pump gas.
[Re: 72swgnr]
#798281
09/11/10 01:01 PM
09/11/10 01:01 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
With the stock type Magnum rockers, you will pick up additional valve lift. They are 1.6 ratio instead of the LA 1.5 ratio. Probably not a problem and will help breathing, just be sure to check piston/valve clearance and valve train clearances during your build. You'll probably need to have the top of the valve guides milled down some.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: 72swgnr]
#798284
09/12/10 10:51 PM
09/12/10 10:51 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
You haven't been able to scare me with the Hemi yet...does that mean mines going to be quicker?
I'm glad you weren't with me when I got air under the front end. Don't worry it'll be plenty fast. Dad
