Dim dash lights #797452
09/09/10 11:55 PM
09/09/10 11:55 PM
Chesterfield, MIch
Cuda67 Offline OP
super street
Cuda67  Offline OP
super street
Chesterfield, MIch
Thanks for any help. I have a 65 Coronet and a 67 Barracuda. Both have dim dash lights. I Have installed new LED bulbs, new headlight switch, checked the bulk head dis-connect (cleaned) ran a ground wire from the dash to the - battery post, and checked the disconnect on the printed circuit board on the back of the dash. Bulbs are still dim. Led helped a bit, but still very dim. HELP.
What else can I do? I did this to one car the 67.
Re: Dim dash lights [Re: Cuda67] #797453
09/10/10 02:22 PM
09/10/10 02:22 PM
BDW Online content
BDW  Online Content
Measure the voltage right at the bulb. You might be getting a voltage drop due to old/bad wiring.
Re: Dim dash lights [Re: BDW] #797454
09/10/10 08:28 PM
09/10/10 08:28 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
There's likely 40+ years of dust in those instrument panels. Make sure the green domes that the bulb inserts into are clean inside and out. The layer of dust could be reducing your light output.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
