leveling the frame for front clip swap? #796201
09/08/10 12:48 PM
09/08/10 12:48 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
so i got the car leveled front to back/side to side, measured about 300 times and cut the front clip off of my 47 desoto. i have an 88 dakota front clip to go on. i have about the front half of the dakota frame(much longer than i need) what can i use to set the level on to level it front to back?
Re: leveling the frame for front clip swap? [Re: 65rbdodge] #796202
09/08/10 10:32 PM
09/08/10 10:32 PM
Oklahoma City, OK
moposcar Offline
moposcar  Offline
Oklahoma City, OK
Don't know if this will help, but the fat man fab front stub I used had me measure from the floor to the top of the core support mount before I cut the frame, then when I put their front clip into my frame rails, I just had to jack the front up where their core support was the same height or a little lower than the original core support mount height. Easier to shim the core support up than try to get it to go down.
Re: leveling the frame for front clip swap? [Re: moposcar] #796203
09/09/10 08:57 AM
09/09/10 08:57 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Seems to me the Dakota frames were level at the bottom of the side rails, but I have a factory service manual in the shop that has frame alignment specs, let me check that today, and I will let you know tonight.
I believe someone posted a copy of the Dakota frame specs on this forum at one time, might still be here someplace. Gene
Re: leveling the frame for front clip swap? [Re: poorboy] #796204
09/09/10 10:36 AM
09/09/10 10:36 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
