Re: Going from 4.10 to 4.30 how much RPM
[Re: 10secGTX]
#795882
09/08/10 12:31 AM
09/08/10 12:31 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I bought a DANA 60 w/4.30 gears last year how much rpm difference at the stripe ....I hear about 300rpm ...what do you guys think? Specs 440 eagle rods 275 60 15 Drag Rad. 8"ATI CONVERT
WITH 4.10 I was going thru @ 6600 6700
Your correct the difference will be about 300 RPM, mike
[Re: 70blackfish]
#795885
09/08/10 06:39 PM
09/08/10 06:39 PM
Posts: 767 NW PA
V10nacuda
NW PA
GO TO Wallace calculators You can find the gear calc... enter your variables & print out a nice chart.... Did that when I went to 4.88's from 5.13's. Picked up 5mph.....now considering 4.56's V10
[Re: 70blackfish]
#795886
09/08/10 06:45 PM
09/08/10 06:45 PM
Sport440
Canton, Ohio
dont mean to Hijack...what about from 4.56 to 4.10?
around 670 rpm, mike
[Re: VernMotor]
#795888
09/08/10 09:43 PM
09/08/10 09:43 PM
Sport440
Canton, Ohio
I went from 4.30 to 4.10 it was about 200 rpm did,t make no diff in the et slip
Its probably important to Note. That similer rpm changes can be had by different tire diameters.
With 3.91,s and a 27.3" tire and swapping to a 26" tire the mathmatical RPM difference is 306 RPM between the two different tire Diameters.
My car was faster with the taller tire and less RPM. Even though the 26" tire had More gear leverage.
Theres a "Sweet spot" with everything, combined in the "Combo"
And Were All never done, looking for them to all match up, mike
[Re: 10secGTX]
#795889
09/09/10 12:09 AM
09/09/10 12:09 AM
Posts: 4,207 New York
polyspheric
New York
Going from 4.10 to 4.30 how much RPM?
Really? Need a calculator? The answer is still the same as it was the last 500 times: new ratio ÷ old ratio. In this case 4.88%, for 6,600 it's 322 RPM.
The are almost no relationships in cars that are anything but a direct comparison just like that (and most people get the others wrong anyway).
Boffin Emeritus
[Re: polyspheric]
#795890
09/09/10 02:03 AM
09/09/10 02:03 AM
Sport440
Canton, Ohio
Im missing some of your math,
the 322 RPM is right.
the 4.88% is right
but the new ratio/ by the old = 1.0487804878
Okay, I see the .0487804878 part in the equation, So if you lose the 1. move the decimal two points I see the 4.878 But thats not the way to get to 4.88%
How does one divide the new ratio from the old without a calc. mike At 1.01 am and Im a head, mike
[Re: Cab_Burge]
#795894
09/09/10 11:05 AM
09/09/10 11:05 AM
polyspheric
New York
This is true - the math is simple, but the results are confusing. If the engine turns too fast with the 4.30 the MPH will go down even more, etc.
How do you do it without a calculator? Uh.... the way you did in school, for the last 2,500 years?
Boffin Emeritus
[Re: polyspheric]
#795897
09/09/10 03:39 PM
09/09/10 03:39 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
I have been taught that math occurred in or around 3000 BC, 3000 BC and 2010 equal 5010, not 25000 years ago I'm not a PHD in math so maybe my math is inaccurate As in all things scientific, especially racing, not all theory are accurate or valid until tested and verified
[Re: VernMotor]
#795898
09/09/10 06:13 PM
09/09/10 06:13 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
glad to see that, i did the same thing just for better street manors,havnt taken it to the trak.
