904 Transmission, Won't hold back in second gear??? #795879
09/08/10 12:14 AM
09/08/10 12:14 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I have a Dodge dart with a rebuilt 904 Transmission, It won't hold back in second gear, but pulls up hill in second ok, I,m thinking kickdown band needs to be reajusted!
So if that is whats wrong, wear can I find the tool I need to fit on the band adjuster??
Re: 904 Transmission, Won't hold back in second gear??? [Re: Hoop] #795880
09/08/10 09:02 AM
09/08/10 09:02 AM
scratchnfotraction Offline
5/16" open end wrench or a 5/16" 8 point 1/4" drive socket fits the square end of adjuster bolt
3/4 boxed end for the lock nut
72 inch pounds or hand snug the adjuster and back off 2 turns
hold adjust from turning while tightning the 3/4 lock nut
good luck
