b body headliner #79532
06/25/08 02:36 PM
06/25/08 02:36 PM
new york
badsixpack Offline OP
new york
I need a headliner in my 69 super bee,everyone I ask says the back window has to be removed,I would rather not, any ideas?....Pete
Re: b body headliner [Re: badsixpack] #79533
06/25/08 02:46 PM
06/25/08 02:46 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Pete, mine was installed with the back and the front windshields in place! No problem.
John
Re: b body headliner [Re: badsixpack] #79534
06/25/08 02:48 PM
06/25/08 02:48 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
I put mine in by myself with both the front and rear glass still in place, over the corse of a weekend.
First time I ever did it and it turn out very nice.
Might be easier with the window out, but I can verify
that it doesnt have to be out to install a headliner.
Just go slow and easy. Dont cut anything until you are sure it needs to be cut.
Cut the hole for the dome light last. I have seen way to
many do it yourself attempts where they have a big nasty
cut or gap next to the dome light where they didnt have it fully installed and cut the dome light area out. You can "fish" the wires out after its cut.
Re: b body headliner [Re: BADBEE] #79535
06/25/08 03:02 PM
06/25/08 03:02 PM
And another tip, go ahead and put the screws for the dome lights, visors, coat hooks, etc. in place before you install the headliner. After it's in, you can feel them through the headliner. It makes locating the screw holes and cutting the headliner easier and more accurate.
One other thing, when you're stretching your headliner and fastening it into place, be cognizant of the tension you end up with where the coat hooks (or lights)have to go. If you stretch it to tightly in those areas, it may wind up too tight once you install the hooks or lights. I hope that made sense.
Good luck - I'm sure it will turn out great.
Re: b body headliner #79536
06/25/08 05:22 PM
06/25/08 05:22 PM
new york
new york
Thanks guys for your help..
Re: b body headliner [Re: badsixpack] #79537
06/25/08 06:32 PM
06/25/08 06:32 PM
I HAVE A GUY NEAR YOU WHO PUTS THEM IN, no back glass has to be removed, if he says it has to be removed, move on,hes an amateur looking for more money.$200.00 to do mine.
Re: b body headliner [Re: badsixpack] #79538
06/25/08 07:22 PM
06/25/08 07:22 PM
Too bad you're not closer to me. I'd help you put it in for nothing.
You won't have any problems.
Re: b body headliner [Re: badsixpack] #79539
06/26/08 10:27 AM
06/26/08 10:27 AM
twin cities
dart_sportsatellite Offline
twin cities
Do a search here or even google headliner or Restorick for some really good installation instructions...I used his instructions and am very happy with the way mine turned out, with the windshield and back window still in the car.
Re: b body headliner [Re: badsixpack] #79540
06/26/08 01:32 PM
06/26/08 01:32 PM
None
71rm23 Offline
71rm23  Offline
None
I'd say that everyone you asked is high...LOL
Re: b body headliner [Re: 71rm23] #79541
06/27/08 09:48 AM
06/27/08 09:48 AM
new york
new york
well, not everyone i asked,but the two places i called that have a good rep. told me the same thing.
Re: b body headliner [Re: badsixpack] #79542
06/27/08 10:02 AM
06/27/08 10:02 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Re: b body headliner [Re: RestoRick] #79543
06/27/08 12:44 PM
06/27/08 12:44 PM
None
71rm23 Offline
71rm23  Offline
None
Here's the Headliner Installation link !
YES>>Check out Rick's install link..
Re: b body headliner [Re: RestoRick] #79544
06/30/08 11:01 PM
06/30/08 11:01 PM
OK
David_Trimble Offline
OK
Does anything special need to be done for '69 (or even '68 or '70 for that matter) Chargers- particularly in the rear window area?
Thanks!
David
'69 Dodge Charger R/T
Re: b body headliner [Re: David_Trimble] #79545
06/30/08 11:31 PM
06/30/08 11:31 PM
WI
RestoRick Offline
RestoRick  Offline
WI
The rear corners are probably the hardest area to get right...
It can take a bit of stretching in a couple directions.
Also be sure that you have the short bow for those corners.
I remember doing a '70 Charger headliner for the original owner. He mentioned that the passenger side rear corner always "hung funny" and had a wrinkle. I found that corner never had a bow installed !
Rick
