O-ring for speedometer gear housing? #79521
06/25/08 01:41 PM
06/25/08 01:41 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Where can I get one? no one seems to know a part number or size for a match up got any ideas? Thanks
Re: O-ring for speedometer gear housing? [Re: rck850] #79522
06/25/08 01:51 PM
06/25/08 01:51 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
hell any transmission shop should have a ton of them laying around or the dealer
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: O-ring for speedometer gear housing? [Re: dusturbd340W5] #79523
06/25/08 02:28 PM
06/25/08 02:28 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yes, there should be a kit from the dealer. One big O ring, one small round seal and a new spring clip, IIRC. I think I ordered mine from Mancini.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: O-ring for speedometer gear housing? [Re: rck850] #79524
06/25/08 02:37 PM
06/25/08 02:37 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I just bought them at O'Reilly Auto Parts.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: O-ring for speedometer gear housing? [Re: rck850] #79525
06/25/08 02:37 PM
06/25/08 02:37 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
It will be a standard size. Take the old one off and
carefully measure the cross section for thickness and the outside or inside diameter. then go to McMaster.com and put in the specs, you will have your order next day.
Re: O-ring for speedometer gear housing? [Re: rck850] #79526
06/25/08 04:53 PM
06/25/08 04:53 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The O ring is 1.750" OD by .100" thick.
Re: O-ring for speedometer gear housing? [Re: rck850] #79527
06/25/08 07:59 PM
06/25/08 07:59 PM
Rocky Hill, Ct
Roadcuda Offline
Roadcuda  Offline
Rocky Hill, Ct
I got a kit for my Roadrunner from Yearone. It had the large outside O-ring, and inner seal. Didn't cost that much either.
65 Coronet 500 convertible
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
www.69roadrunner.net www.plymouthbulletin.com
