Re: O-ring for speedometer gear housing?
[Re: rck850]
#79522
06/25/08 01:51 PM
06/25/08 01:51 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
hell any transmission shop should have a ton of them laying around or the dealer
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#79523
06/25/08 02:28 PM
06/25/08 02:28 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Yes, there should be a kit from the dealer. One big O ring, one small round seal and a new spring clip, IIRC. I think I ordered mine from Mancini.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: rck850]
#79524
06/25/08 02:37 PM
06/25/08 02:37 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I just bought them at O'Reilly Auto Parts.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: rck850]
#79525
06/25/08 02:37 PM
06/25/08 02:37 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Where can I get one? no one seems to know a part number or size for a match up got any ideas? Thanks
It will be a standard size. Take the old one off and carefully measure the cross section for thickness and the outside or inside diameter. then go to McMaster.com and put in the specs, you will have your order next day.
[Re: rck850]
#79526
06/25/08 04:53 PM
06/25/08 04:53 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The O ring is 1.750" OD by .100" thick.
[Re: rck850]
#79527
06/25/08 07:59 PM
06/25/08 07:59 PM
Posts: 1,014 Rocky Hill, Ct
Roadcuda
Rocky Hill, Ct
I got a kit for my Roadrunner from Yearone. It had the large outside O-ring, and inner seal. Didn't cost that much either.
