Hemi pushrod clearance #795047
09/06/10 11:06 PM
09/06/10 11:06 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
How do you achieve pushrod clearance?
I needed to get some clearance on 3 of the 8 exhaust pushrods. These are Stage V heads. In the past I have always used die grinder with a long carbide burr. But it's time consuming, messy, and never that exact.
This time I tipped the head of my mill about 18 degrees on the Y axis and 3 degrees on the X axis and used a slightly undersized 5/8 end mill to egg shape the holes by about .055". I went ahead and did them all.
Time was 1 hour for the first head (including setup time) and 15 minutes for the second.
No more grinder for me!
Re: Hemi pushrod clearance [Re: GregCon] #795048
09/06/10 11:13 PM
09/06/10 11:13 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am surpirsed they weren't clearanced enough already. The problem I have seen is usualy the gaskets hit the push rods. I am not sure if its the Barton T&D rocker set-up or the gaskets, but I have now seen it twice with those rockers. Never seen the issue with the heads, but they were close.
Re: Hemi pushrod clearance [Re: GregCon] #795049
09/06/10 11:22 PM
09/06/10 11:22 PM
Delray beach, Florida
P
Performance Only Offline
P
we have several different mini boring bars that we use with the block and heads mocked up for 3/8 7/16 or 1/2" pushrods. we use a corresponding puck in the lifter bore that we can change the height on to match the lifter height that will be used in the build. these are all tools we made in house. after many years of doing it with the mill or die grinder we decided there was indeed a better way.
machine shop owner and engine builder
Re: Hemi pushrod clearance [Re: Performance Only] #795050
09/06/10 11:57 PM
09/06/10 11:57 PM
Houston TX
GregCon Offline OP
GregCon  Offline OP
Houston TX
That's good Dan, 'cause these are going on the block that you will soon be seeing!
I haven't assembled a Hemi yet that didn't need some sort of clearancing on the pushrods. I was actually pretty happy to see this engine needed only work on the three exhausts and no intakes.
Re: Hemi pushrod clearance [Re: GregCon] #795051
09/07/10 08:31 AM
09/07/10 08:31 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Mine had tubes put in them since the ports break into the push rod area when ported, but they do have an added benefit of extra clearance.
I got some Cometic gaskets through FHO that have the push rod area either removed or pre-clearanced.
Re: Hemi pushrod clearance [Re: GregCon] #795052
09/07/10 09:02 AM
09/07/10 09:02 AM
an8sec70cuda Offline
I used a long shank bur bit on my die grinder. My block (KB) needed a bunch of clearancing. The heads and gaskets (MP and Cometic) fit fine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi pushrod clearance [Re: an8sec70cuda] #795053
09/07/10 11:34 AM
09/07/10 11:34 AM
Modesto, CA
Chris_Holton Offline
Modesto, CA
I have a remer and add tubes, looks very clean...
