Tested shift points today #794865
09/06/10 09:35 PM
09/06/10 09:35 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I spent today at the track testing shift points. The weather didn't change much during testing, 11:30am to 5:43pm; so that is helpful. Temp varied from 83 to 88 and then went back down to 84 for the last run (83,87,88,88,86,84).
I made two passes at each shift rpm. The order of the runs was 6500, 6700, 7000, 6700, 7000, 6500.
There was very little difference, so for this post I averaged the two runs at each shift point for comparison:
6500 - 6700 - 7000
5.893, 5.878, 5.876 Eighth mile ET
115.7, 115.8, 115.2 Eighth mile speed
9.333, 9.304, 9.300 Quarter mile ET
141.9, 142.2, 142.3 Quarter mile speed
One of the 7000 rpm runs had an unusally low 1/8 mph, and that effected the average. The other 7000 rpm mph was higher than all the others, so it had the highest and lowest. So the 1/8 mph number may not be worth using.
I guess 6500 is too low, but the difference between 6700 and 7000 may be too close to call.
Re: Tested shift points today [Re: 440Jim] #794866
09/06/10 11:00 PM
09/06/10 11:00 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thanks for the comprehensive info Jim, as Always
IMO, shift points no doubt will depend on the engines HP sweet spot. So the sweet spot will be different with most engines, but still within 1000 RPM for 90% of us 6000 RPM to 7000 RPM IMO
While I havent done much testing, IMO I think there may be an advantage to Dual shift points between first and second/third.
Since the first gear is the best Multipling gear , I think a couple hundred RPM above the sweet spot may be beneficial on the 1st to 2nd shift compared to the 2nd to 3rd. shift point.
Or not, mike
Re: Tested shift points today [Re: Sport440] #794867
09/06/10 11:02 PM
09/06/10 11:02 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
What happened to +7500? Oooh its a wedge, sorry.
Just teasing. Looks very fast! I have not seen any wedge motors that fast at our local 1/8th in a while.
Re: Tested shift points today [Re: Dragula] #794868
09/06/10 11:10 PM
09/06/10 11:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Good post Thankx Jim
Re: Tested shift points today [Re: Dragula] #794869
09/06/10 11:13 PM
09/06/10 11:13 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
LOL
This engine has a flat tappet cam, not a roller cam. So I don't expect it to rpm too high. Plus at 511 CID, and run of the mill Indy 440-1 heads (nothing fancy, no CNC, etc); I am happy to see it didn't fall off shifting at 7000.
The cam is on 110 LSA, so it looks like the power curve is pretty broad (ie not a 106 LSA cam).
Re: Tested shift points today [Re: 440Jim] #794870
09/06/10 11:23 PM
09/06/10 11:23 PM
Az
Crizila Offline
Crizila  Offline
Az
In both cases ( ET and MPH ) the change is less than 1% - and with only 3 points to look at -
Fastest 300
Re: Tested shift points today [Re: 440Jim] #794871
09/06/10 11:52 PM
09/06/10 11:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Jim with my 10.0 set up a couple hundred rpm's are
worth right at .020... thats with a mech throttle stop
on it so its not a apples to apples test... it ran a
string (7) 10.00 and then Doug stretched the rpm and
ran a 9.98
Re: Tested shift points today [Re: Crizila] #794872
09/06/10 11:54 PM
09/06/10 11:54 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Yea, the shift point didn't have much effect. Some guys would love to have a bracket car that didn't change much when they missed the shift point.
Re: Tested shift points today [Re: 440Jim] #794873
09/07/10 12:05 AM
09/07/10 12:05 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
And This guy, If the change in both cases ( ET and MPH ) is less than 1% would be shifting at 6500 vs 7000 RPM. mike
Re: Tested shift points today [Re: Sport440] #794874
09/07/10 10:57 AM
09/07/10 10:57 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Curious, what does it go through the lights at in the 1/4 on the 7000rpm shifts vs the 6700rpm shifts?
My flat tappet 500 really had its tongue hanging out going from 6800rpm shifts to 7000rpm shifts. It definitely wasnt worth it in my case. Of course my sled is a touch heavier than yours too.
You mind sharing those cam specs again? I know they have been posted before, but I dont remember what they were.
Re: Tested shift points today [Re: 66coronet] #794875
09/07/10 11:40 AM
09/07/10 11:40 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I had been running 4.30 gears for the last few years. However, a couple pinion teeth broke a couple weeks ago, so I put my old 4.56 gears back in to get me through the rest of the season. That was one reason I decided to go through the shift point tests.
At 142 mph, the tach read 7150 at the finish line. Since all the runs had very close mph, the rpm was the same. With the 4.30 gears it was about 300 rpm less.
The cam is a Comp Cams shelf grind, MM-305S-10:
305º/320º@.020", 279º/287º@.050", 197º/200º@.200", 0.650"/0.630" lift published (0.690/0.670 with my 1.6 rockers), 110 LSA. I am running 150 lbs seat pressure and 440 open with EDM oiling flat tappets.
Re: Tested shift points today [Re: 440Jim] #794876
09/07/10 12:47 PM
09/07/10 12:47 PM
PA
moparacer Offline
moparacer  Offline
PA
My 500 Indy headed Engine likes 6900 but any less then that it will start to slow.
Curious Jim, what converter setup do you run in your car?
I have a similar setup with 4.56s, 32 tall tire and at 138 MPH I am crossing at about 7150 just like you in the weather we have now.
Mine's a glide with a 8 inch ATI.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Tested shift points today [Re: 440Jim] #794877
09/07/10 01:22 PM
09/07/10 01:22 PM
Az
Crizila Offline
Crizila  Offline
Az
I think a lot of guys like to throw out those big RPM #'s and a lot of them are shifting @ higher rpm's than they really need to. It would be interesting to run the test with 500rpm intervals. When I was racing seriously I always found that I had the best ET's when I ran out of motor just before the ET light - crossing at 4-500 rpm above the shift rpm. MPH suffered some what though - as did engine longivity .
Fastest 300
Re: Tested shift points today [Re: Crizila] #794878
09/07/10 11:11 PM
09/07/10 11:11 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
It would be interesting, but I figured the best would be in the 6500-7000 range and 200-300 rpm change was what I had time for. I expected to get 4 passes at this event, so every pass after that I had to make a guess what would be the best one to try. I like to have more than one pass at each condition to be sure, since track testing isn't always dead-on repeatable.
727 trans, 32" tires, Dynamic 9" converter. I also have a Coan 8" restalled by PTC that runs the exact same ET. I bought both used as a bargin hunter.
