Best way to remove paint from shaker ring? #794616
09/06/10 07:07 PM
09/06/10 07:07 PM
Wausau Wi
Convertcuda Offline OP
Wausau Wi
Stripper people say could cause problems?
Sandblasting eats the metal?
How about worn glass beed on low pressure
Thanks Moparts
Re: Best way to remove paint from shaker ring? [Re: Convertcuda] #794617
09/06/10 08:26 PM
09/06/10 08:26 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Use full strength aircraft paint stripper, it won't harm an original at all. DO NOT blast it with anything! That's where you can start causing damage.
Re: Best way to remove paint from shaker ring? [Re: Convertcuda] #794618
09/06/10 08:49 PM
09/06/10 08:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I done a few in the past with glassbead, no distortion, just don't lay on it for any time, if it has a ton of repaints on it, strip most of the crud with stripper, the glassbead will put some tooth on the part for paint to stick,...use a good quality etch primer because it's basically aluminum (potmetal) base primers will peel down the road, causing paint finish problems
Re: Best way to remove paint from shaker ring? [Re: DAYCLONA] #794619
09/06/10 11:18 PM
09/06/10 11:18 PM
Wausau Wi
Wausau Wi
Hi Scott,
The reason I got alarmed is this. Someone told if use paint strip on it - it gets into the pours of the potmetal and it is hard to clean out. Then when it sits out in the hot sun it resurfaces causing the new paint to left. Any thought on this?
Ken
Re: Best way to remove paint from shaker ring? [Re: Convertcuda] #794620
09/07/10 12:01 AM
09/07/10 12:01 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
crushed walnut shells, or baking soda works if you have the equipment. takes the paint, but not the metal. i've seen guys do damage with glass beading. the aircraft stripper sounds interesting. you know they have a lot of supervisory regs, dealing with the FAA and what you can and cant use. i would imagine anything they use, has been tested and documented as safe.
Re: Best way to remove paint from shaker ring? [Re: Golden-Arm] #794621
09/07/10 12:13 AM
09/07/10 12:13 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The sell the aircraft stipper at Home Depot here, it's not a big deal. I have used it ALLOT with no painting issues after a good rinse in plain old water and thinner.
