Preserving a fuel pump
#794587
09/06/10 06:54 PM
09/06/10 06:54 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I removed my old one...Carter...it works...but I want to keep it as a spare and don't want to varnish the inside of it. Is there anything I can pour into it to "cleanse it" so I can put it in a box in case I need it in the future?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Preserving a fuel pump
[Re: Challenger 1]
#794589
09/06/10 09:47 PM
09/06/10 09:47 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I would watch out for WD-40 sometimes it does not play well with rubber. I have see it swell rubber o rings and gaskets. I would think if it is drained completely you would be OK maybe run some Sta-bil fuel stabilizer through it. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#794590
09/07/10 04:15 AM
09/07/10 04:15 AM
Pyper70
Athens, Greece
Cool...I'll drain it out.....Blow some compressed air through it...blow some carb spray through...Blow it out again...and drip some sta-bil into it and cap off the ports.
[Re: 70Cuda383]
#794592
09/07/10 10:05 AM
09/07/10 10:05 AM
Pyper70
Athens, Greece
well it wasn't going to be alot, just nozzle pressure (40psi) to blow the carb spray out...but okay...I wont blow anything through it...
