Preserving a fuel pump #794587
09/06/10 06:54 PM
09/06/10 06:54 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I removed my old one...Carter...it works...but I want to keep it as a spare and don't want to varnish the inside of it. Is there anything I can pour into it to "cleanse it" so I can put it in a box in case I need it in the future?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Preserving a fuel pump [Re: Pyper70] #794588
09/06/10 07:27 PM
09/06/10 07:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Waterman Racing Fuel Pumps ships there fuel pumps with a small bottle of silicone fluid used to store it with.
I'd go with WD 40 and plug the openings.
Re: Preserving a fuel pump [Re: Challenger 1] #794589
09/06/10 09:47 PM
09/06/10 09:47 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I would watch out for WD-40 sometimes it does not play well with rubber. I have see it swell rubber o rings and gaskets.
I would think if it is drained completely you would be OK maybe run some Sta-bil fuel stabilizer through it.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Preserving a fuel pump [Re: finadk] #794590
09/07/10 04:15 AM
09/07/10 04:15 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Cool...I'll drain it out.....Blow some compressed air through it...blow some carb spray through...Blow it out again...and drip some sta-bil into it and cap off the ports.
Re: Preserving a fuel pump [Re: Pyper70] #794591
09/07/10 09:58 AM
09/07/10 09:58 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
NOO!!! DO not blow air through it!!!! they have rubber diaphrams in them that could rupture under the high air pressure of an air compressor. I'd do everything BUT blow compressed air through it.
**Photobucket sucks**
Re: Preserving a fuel pump [Re: 70Cuda383] #794592
09/07/10 10:05 AM
09/07/10 10:05 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
well it wasn't going to be alot, just nozzle pressure (40psi) to blow the carb spray out...but okay...I wont blow anything through it...
