Cleaning White Letters on Tires #79392
06/25/08 07:42 AM
06/25/08 07:42 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Online content OP
moparmike1  Online Content OP
Hi,
I bought a set of reproduction Polyglas raised white letter tires last year and the white letters were nice and bright. I removed the tires and rims for the winter and have been sitting in my garage since this past weekend. No exposure to sun, painting, etc., just sat in the corner of the garage.
Now the white letters have taken on a light yellow/brown appearance. What would anyone suggest using to clean the letters to bring them back to white. I have tried dishwashing soap and car wash soap but neither helped.
Thanks,
Mike.
Re: Cleaning White Letters on Tires [Re: moparmike1] #79393
06/25/08 07:56 AM
06/25/08 07:56 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I've always used Westley's Bleche-Wite. You can find it at pretty much any place that sells car cleaning stuff.
Re: Cleaning White Letters on Tires [Re: moparmike1] #79394
06/25/08 07:56 AM
06/25/08 07:56 AM
Southeastern Ohio
1st_charger Offline
1st_charger  Offline
Southeastern Ohio
I found by accident that armoral wheel cleaner, for aluminum and mag wheels, the stuff you just squirt on and let sit for 10 minutes and then hose off actually brightens up white letters very good. I just squirt it on and let it set for 2 minutes and then scrub the tire and rinse it off.
Re: Cleaning White Letters on Tires [Re: 1st_charger] #79395
06/25/08 08:21 AM
06/25/08 08:21 AM
scratchnfotraction Offline
westlys tire bleach...good stuff!
the westleys spay silacone for tires is good stuff also and goes with the bleaching
makes them look like they are armrall down,but the dirt will not stick to the tire
drive on a dirt road,wipe tire with a dry cloth and looks good
wont see that with the armrall
I used to take a red permenant marker and color the out line white letters, like redline tires ,did blue to match the car paint,yellow like nascar rubber also
they make a white oil/chalk stick for dressing up white letters in the parts store too,thats good if they have been scuffed on a curb
Re: Cleaning White Letters on Tires [Re: Paul_B] #79396
06/25/08 08:31 AM
06/25/08 08:31 AM
the house on the left.
cogen80 Offline
cogen80  Offline
that stuff is the best. spray it on and use a soft scrub brush in them and they come out clean as hell.
Re: Cleaning White Letters on Tires [Re: Paul_B] #79397
06/25/08 08:36 AM
06/25/08 08:36 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
works awesome. I've had tires grimed up so bad you couldn't tell they were whitewalls clean up and look like new with it.
2017 Grand Cherokee Overland
Re: Cleaning White Letters on Tires [Re: scratchnfotraction] #79398
06/25/08 09:01 AM
06/25/08 09:01 AM
Spring, Texas
RedFish Offline
super street
RedFish  Offline
super street
Spring, Texas
Back in the day, this is what we used.
Howard
You don't stop playing games when you get old, You get old when you stop playing games.
Re: Cleaning White Letters on Tires [Re: moparmike1] #79399
06/25/08 09:25 AM
06/25/08 09:25 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
After staining the paint on my wheels with the Westleys, bad stuff; I now use Eagle One Tire and Wheel cleaner. Works great and is safe for the paint. Will never use Westleys again.
Re: Cleaning White Letters on Tires [Re: 469runner] #79400
06/25/08 09:44 AM
06/25/08 09:44 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Spray nine cleaner has worked the best for me. If all else fails and you can`t get them clean try a little lacquer thinner on a rag and only wipe the white letter carefully. Mike
Re: Cleaning White Letters on Tires [Re: mopars4ever] #79401
06/25/08 09:52 AM
06/25/08 09:52 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Comet or Ajax and a nylon brush.
Re: Cleaning White Letters on Tires [Re: Neil] #79402
06/25/08 10:05 AM
06/25/08 10:05 AM
SW MO
closer9 Offline
closer9  Offline
SW MO
I just take it to the car wash, and use the high pressure soap. Spray it from just a few inches away, and they always come clean. I used to use Wesley's till I saw what it did to clear coat...
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Cleaning White Letters on Tires [Re: closer9] #79403
06/25/08 10:13 AM
06/25/08 10:13 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
If worse comes to worse, get some wet/dry paper and a block and sand them down a bit.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Cleaning White Letters on Tires [Re: moparmike1] #79404
06/25/08 10:30 AM
06/25/08 10:30 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I've used SOS pads for years now. They work great!
Re: Cleaning White Letters on Tires [Re: 318 Stroker] #79405
06/25/08 11:50 AM
06/25/08 11:50 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
back in the early '70s, I remember Dad using a wire brush to clean the double whitewalls
1981 Dodge D150 360 auto
Re: Cleaning White Letters on Tires [Re: basketcase] #79406
06/25/08 12:06 PM
06/25/08 12:06 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Go blackwall and forget about them
Re: Cleaning White Letters on Tires [Re: moparmike1] #79407
06/25/08 12:28 PM
06/25/08 12:28 PM
Here's another vote for Westley's. Never had a problem staining paint, but I scrub and rinse while it's still wet. It does have bleach in it and can stain paint, and aluminum, too, if you let it dry before rinsing, especially in hot sunlight.
For really stubborn dirt/stains, I scrub with 0000-grade steel wool; otherwise, a soft-bristle scrub brush works fine.
Re: Cleaning White Letters on Tires #79408
06/25/08 12:59 PM
06/25/08 12:59 PM
USA
b54406barrel Offline
USA
I use an inexpensive, foam spray called 'tuff stuff'. It's in a red & yellow can & about every store in the world carries it. Works pretty well & doesn't run all over when you spray it on.
Re: Cleaning White Letters on Tires [Re: b54406barrel] #79409
06/25/08 01:43 PM
06/25/08 01:43 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Westleys. Never a problem in 25 years.
Re: Cleaning White Letters on Tires [Re: Aero426] #79410
06/25/08 01:46 PM
06/25/08 01:46 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
I also use Westley's. I use Spray-Nine for other things and always have it around the house though. Maybe I'll try that next time just to cut down on the amount of different cleaning products that I keep around the house.
No longer taking $h!t from anyone!
Re: Cleaning White Letters on Tires [Re: DUFFMAN] #79411
06/25/08 02:10 PM
06/25/08 02:10 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Westley's kicks [Edited by Moparts - Keep it clean]. I use it to clean thos plastic patio chairs, the cooler, the garage door...
