Re: Dynamic 9.5 converter
[Re: We The People]
#794041
09/06/10 07:11 AM
09/06/10 07:11 AM
Posts: 70 New Jersey
Randy514
New Jersey
We have a 9.5 Dynamic converter in our 73 Cuda 522 RB 730 Roller Pro Comp heads 411 Ratio Car weighs 3550 with driver Speced for a trans brake but we're footbraking it. Estimate 650 at the rear wheels Its been 10.40@130 Flashes to 5400 We have about 30 passes with no issues Randy
[Re: Fast Yeti]
#794043
09/06/10 09:33 AM
09/06/10 09:33 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Thanks for the feedback guys I had a new custom converter built for the 572 but it won't seat properly in the trans. It looks like the hub is shorter than it needs to be and the anti balooning plate is contacting the front seal. I'll call Dynamic and see what they have to say but i'm thinking this converter won't hold up for any length of time. It was originally specced for a 383 race application. This really bites because i was hoping to have the car at Norwalk. Ron
[Re: firefighter3931]
#794044
09/11/10 12:37 PM
09/11/10 12:37 PM
firefighter3931
Ontario,Canada
Update ; we spoke with Dynamic and Frank said the 9.5in unit is waaaay too loose for the current combo. He predicted it would stall at 6000 with the 572. The custom converter is back with the builder and he's fixing it. The fitment issue is the Stator splines which are too tall and the converter is bottoming out on the stator support before the input shaft and pump lugs are fully engaged. The converter needs another 1/2in of travel to seat properly. This was confirmed by my trans guy Doug Miller (Fireball Transmissions) I should have the converter back sometime this week with any luck. Unfortunately this setback means i won't make Norwalk. Ron
#794047
09/11/10 05:32 PM
09/11/10 05:32 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
I have had flawless perfomrance with Frank Lupo/Dynamic converters. I have not tried the 9.5 though.
8.30's @3400 lbs
