Quarter and Rocker panel replacement?? #793444
09/05/10 02:47 PM
09/05/10 02:47 PM
Newfoundland
Crocker Offline OP
Crocker  Offline OP
Newfoundland
On an E body. In what order do you remove and replace the panels? Is it the quarter or rocker first?
Re: Quarter and Rocker panel replacement?? [Re: Crocker] #793445
09/05/10 03:22 PM
09/05/10 03:22 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
If your dutchman panel needs replacing, I would do that one first then the quarter, then the rocker panel.
Cut the dutchman just on the inside of the seam.
Re: Quarter and Rocker panel replacement?? [Re: Topcat] #793446
09/05/10 03:32 PM
09/05/10 03:32 PM
Newfoundland
Crocker Offline OP
Crocker  Offline OP
Newfoundland
the dutchman panel is fine.
Re: Quarter and Rocker panel replacement?? [Re: Topcat] #793447
09/05/10 03:36 PM
09/05/10 03:36 PM
Newfoundland
Crocker Offline OP
Crocker  Offline OP
Newfoundland
So the rocker panel overlaps the quarter at the mating seam?
Re: Quarter and Rocker panel replacement?? [Re: Crocker] #793448
09/05/10 03:42 PM
09/05/10 03:42 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
No quarter over laps rocker. Really they just meet. Should be leaded there. Too much thickness to do body filler.
Re: Quarter and Rocker panel replacement?? [Re: Topcat] #793449
09/05/10 03:51 PM
09/05/10 03:51 PM
Newfoundland
Crocker Offline OP
Crocker  Offline OP
Newfoundland
so you can remove and replace the quarter, then remove and replace the rocker and just fit the rocker inside the quarter? Top cat have you got a pic of that seam before filler?
Re: Quarter and Rocker panel replacement?? [Re: Crocker] #793450
09/05/10 04:01 PM
09/05/10 04:01 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Pic with the quarter panel originally. No pic with lead out. Sorry.
Re: Quarter and Rocker panel replacement?? [Re: Topcat] #793451
09/05/10 04:04 PM
09/05/10 04:04 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Pic with quarter panel off.
