2 speed OR 3 speed wiper setup #793356
09/05/10 12:58 PM
09/05/10 12:58 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
I have stripped so many 71 bbodies , I dont know whats what . How do I determine if I have a three speed setup and motor . I dont want to mix match ..
Thanks, Sincerely ignorant
Re: 2 speed OR 3 speed wiper setup [Re: sogtx] #793357
09/05/10 01:23 PM
09/05/10 01:23 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
pretty sure this is a 3 speed wiper motori want to use - anypics of linkage thats appropriate?
Re: 2 speed OR 3 speed wiper setup [Re: sogtx] #793358
09/05/10 02:07 PM
09/05/10 02:07 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
That is a 3 speed wiper motor.
From the blurry part number it looks like one of those
nos 75-77 motors from Volare Aspens that are always for sale.
It will work but will not look correct for 71.
If you are going full original you would need one like this.
Jules
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793359
09/05/10 02:09 PM
09/05/10 02:09 PM
super gas
super gas
Your linkage should look like this.
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793360
09/05/10 02:10 PM
09/05/10 02:10 PM
super gas
super gas
and your cam should look like this
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793361
09/05/10 03:21 PM
09/05/10 03:21 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Not Very interested in looking correct , pro touring project . Must unorthodox 71-72 Hybrid car non matching car ever .. But - THANKS for info on linkage .. Now I know where i can get parts
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793362
09/05/10 03:31 PM
09/05/10 03:31 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
i have this which is one digit off from yours
Re: 2 speed OR 3 speed wiper setup [Re: sogtx] #793363
09/05/10 03:33 PM
09/05/10 03:33 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
and the cams look similar , but the bushing on the drive arm ? is yours missing something ?
Re: 2 speed OR 3 speed wiper setup [Re: sogtx] #793364
09/05/10 04:57 PM
09/05/10 04:57 PM
super gas
super gas
Your linkage is a 2 speed with a 2 speed cam kit and it will not work with that 3 speed motor you have.
I have a 3 speed linkage and cam kit for sale if you are interested.
You must also check your dash switch.
If it is a 2 speed , it will not work with your motor.
Jules
Re: 2 speed OR 3 speed wiper setup [Re: sogtx] #793365
09/06/10 09:43 AM
09/06/10 09:43 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
ok i got a 3 speed setup , funny , I figured that the more complicated one would be a 3 speed
Now , it should be easy enough to identify a three speed switch , i am assuming three clicks on the switch .. Is every rallye dash harness created equally with wiper wiring ?
Re: 2 speed OR 3 speed wiper setup [Re: sogtx] #793366
09/06/10 10:22 AM
09/06/10 10:22 AM
super gas
super gas
A 71 B body has a variable speed switch.
One click, then a rheostat type sweep.
"Is every rallye dash harness created equally with wiper wiring"
EVERY is a big word. If you have a 71 dash wiring your plugs will look like this.
Jules
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793367
09/06/10 10:34 AM
09/06/10 10:34 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
i definitely founda rheostat switch , thanks .
So I am assuming that the dash wiring is same no matter whether 2 speed OR 3 speed
Re: 2 speed OR 3 speed wiper setup [Re: sogtx] #793368
09/06/10 01:42 PM
09/06/10 01:42 PM
super gas
super gas
The wiring is the same.
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793369
09/09/10 11:17 PM
09/09/10 11:17 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Thank You Mr Wiperman , I appreciate your help ..
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793370
09/10/10 08:58 AM
09/10/10 08:58 AM
super gas
super gas
You're welcome
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793371
09/10/10 09:11 AM
09/10/10 09:11 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
JulesdaWiperman you a are the best
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 2 speed OR 3 speed wiper setup [Re: 440beep] #793372
09/10/10 01:36 PM
09/10/10 01:36 PM
super gas
super gas
Thank you.
Only trying to help.
Jules
Re: 2 speed OR 3 speed wiper setup [Re: JulesdaWiperman] #793373
09/12/10 11:29 AM
09/12/10 11:29 AM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Yep Jules is the wiper guru I guess the give away on the later version wiper motor would be the plastic cover instead of the flat steel piece, am I correct there?
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: 2 speed OR 3 speed wiper setup [Re: G-Money1320] #793374
09/12/10 01:18 PM
09/12/10 01:18 PM
super gas
super gas
Yes, early 72 and on.
jules
