Re: 4.7 vacuum leak
[Re: Mr.Yuck]
#793308
09/05/10 12:41 PM
09/05/10 12:41 PM
remove the idle air plunger from the throttle body--two Torx screws--clean the carbon off the plunger and the seat inside--might just do the trick only take 5 minutes
Re: 4.7 vacuum leak
[Re: Mr.Yuck]
#793310
09/05/10 02:05 PM
09/05/10 02:05 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have seen the little rubber hose colapse on the outside of the corner and makes a sucking noise. I can't remember witch hose it is mabey PCV ?
Re: 4.7 vacuum leak
[Re: ditchdrift]
#793312
09/06/10 11:31 AM
09/06/10 11:31 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
really sounds brake booster related. make sure the booster is retaining vaccuum.
I hope it's not the booster. but you can hear the hiss by the brake pedal.... but when you check outside in the engine bay the sound is loudest by the TB.
Re: 4.7 vacuum leak
[Re: ]
#793313
09/06/10 12:38 PM
09/06/10 12:38 PM
Mr.Yuck
Brookeville, Md
ok that was dirty cleaned..not it. It does sound like the booster is bad. So how many hours does that pay? I guess I can do it but if it's only like an hour I'll pay a shop.
