What fuel lines do you recommend? #793295
09/05/10 11:33 AM
09/05/10 11:33 AM
Tires are smokin , Iowa
1Adam12 Offline OP
super gas
1Adam12  Offline OP
super gas
I see Yearone has fuel lines for my 73 Charger, Are they bent for shipping? Anyoone order these? Are there other suppliers?
Re: What fuel lines do you recommend? [Re: 1Adam12] #793296
09/05/10 12:47 PM
09/05/10 12:47 PM
God's Country - Etowah, TN.
A34 Offline
A34  Offline
Go direct to Fine Lines. I think they are the best on the market compared to others I've seen.
http://www.finelinesinc.com/catalog/index.php?cPath=277
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: What fuel lines do you recommend? [Re: 1Adam12] #793297
09/05/10 12:48 PM
09/05/10 12:48 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
FINELINES from DIXIE RESTORATION! 1st class operation! 770-975-9898
Ray
Re: What fuel lines do you recommend? [Re: rayztoy] #793298
09/05/10 12:50 PM
09/05/10 12:50 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Buy Fine Lines Best available.
CHECK OUT MY NEW WEB SITE !
Re: What fuel lines do you recommend? [Re: anlauto] #793299
09/05/10 05:15 PM
09/05/10 05:15 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
here is a dumb? How do I know what size? 70RR. Was 383..installing 440 6pk. old lines are already out....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: What fuel lines do you recommend? [Re: anlauto] #793300
09/05/10 09:58 PM
09/05/10 09:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
,....FineLines are the ONLY lines to invest in,...I only purchase their Stainless Steel line of brake/fuel/emission lines,....never an issuse
Mike
Re: What fuel lines do you recommend? [Re: DAYCLONA] #793301
09/06/10 12:03 AM
09/06/10 12:03 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Every line on my car is stainless---from Fine Lines
Re: What fuel lines do you recommend? [Re: JMCFAN] #793302
09/07/10 01:24 PM
09/07/10 01:24 PM
Utah
E
Eagleone1983 Offline
E
Utah
First, yes they will be bent for shipping not usually a big deal but you don't have any old ones to compare the new ones with. The bends will be marked so you know where to straighten them out at.
Secondly, the 383 would've had 5/16" lines, I know mine did. the 440 would've had 3/8" lines. Upgrade to the 3/8" lines but keep in mind this also means that your fuel sending unit would also have to be 3/8"
Re: What fuel lines do you recommend? [Re: JMCFAN] #793303
09/07/10 01:56 PM
09/07/10 01:56 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
A 440+6 will have 3/8 lines with a 1/4 return line. Will require a different sender.
Re: What fuel lines do you recommend? [Re: Morty426] #793304
09/07/10 08:47 PM
09/07/10 08:47 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I have fuel and brake lines from Right Stuff Detailing. Top notch stuff. The fit was excellent on all of them. When I went looking for the new lines, my uncle suggested that I stay away from Fine Lines brake lines. He could never get his to seal, and another local guy couldn't either. He has no experience with their fuel lines. Because I needed both, I went to Right Stuff for one stop shopping. I've been very happy with them, and would definitely use them again.
I went with the 3/8" lines even though I have a 383. So far I've never hooked up the return line. No need to yet.
1968 Plymouth Road Runner 383 4 speed
Re: What fuel lines do you recommend? [Re: dobie] #793305
09/07/10 10:13 PM
09/07/10 10:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Were your uncles lines stainless?
Re: What fuel lines do you recommend? [Re: Challenger 1] #793306
09/08/10 07:27 AM
09/08/10 07:27 AM
Ohio
dobie Offline
dobie  Offline
Ohio
Yes, they were stainless.
