You can only guess without real numbers. If the block was milled to properly set deck hieght (not to clean up the decks, but to blueprint it), and the heads are not milled, you have about 72cc or larger heads. Prob be closer to 10.5ish depending. Too high for an iron head engine that needs a high level of vacuum. (meaning smaller cam)
