Re: Dis-assembling rocker shaft on 318 poly heads..
[Re: polkat]
#792975
09/05/10 02:00 AM
09/05/10 02:00 AM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
On top of one of the cylinder head pedastals there is what the service manual calls a "rocker shaft lock plug." That has to be removed before the rocker shaft, rocker arms, springs can be removed. Your heads and engine are sludged up from what i have been reading in your other postings. That's why you can't see the lock plug, with the sludge on the heads. Not to be a critic of your mechanical skills, but a factory maintenance manual would have done wonders for you in your undertaking, what your attempting to do.
RF-4C Phantom 69-370 Zweibrucken, Germany
