Car missing out under load. #792956
09/04/10 11:11 PM
09/04/10 11:11 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
I'll try and keep this question short. Driving Car the other day(440-6 Superbee) and it started backfiring and mising out over 2500 rpm. pulled over changed out ballist resistor and everything seemed fine, drove another 30 miles no prob then on way back home bam!! started doing again, I just swapped old dist(dual points) out with Mopar Elect and fires right up revs into 4000 rpm range no problem idles fine,etc. went out for drive and under acceleration starts missing out and backfiring, let off and runs fine?? I've replaced the coil also with new accel superstock unit, new dist,cap,rotor,and ballist. so i'm kinda at a loss, Before the other day car has been driven alot with no problems.
Re: Car missing out under load. [Re: mc4406] #792957
09/04/10 11:19 PM
09/04/10 11:19 PM
plug or plug wire missing under load? EDIT What ECU?
Re: Car missing out under load. [Re: RapidRobert] #792958
09/04/10 11:28 PM
09/04/10 11:28 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
It has the orange box ecu, and i haven't changed wires yet, they are a few yrs old so i'll do plugs and wires tomorrow.
Re: Car missing out under load. [Re: mc4406] #792959
09/04/10 11:37 PM
09/04/10 11:37 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Loose or fouled up spark plug,or loose plug wire.
A 6bbl car? HHmmm maybe the carbs need adjusting??
A vacuum pod stuck open/opening too soon on the outboard carbs and dumping fuel into the engine??
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Car missing out under load. [Re: 68Cbarge] #792960
09/04/10 11:54 PM
09/04/10 11:54 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
If carbs where the problem would it be able to rev so freely in nuetral? I can rev and hold a 4000 rpm and sounds good, but driving is a different story. Wires and plugs are on the to do list tomorrow.
Re: Car missing out under load. [Re: mc4406] #792961
09/05/10 07:01 PM
09/05/10 07:01 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
4000 RPM and no load is totally different compared to 4000 RPM under a load,IMHO.
The vacuum rating is different under those situations and the outer carbs rely on vacuum to operate when the engine is under a load..
Re: Car missing out under load. [Re: 68Cbarge] #792962
09/05/10 08:08 PM
09/05/10 08:08 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Here is the latest, replaced plug wires and plugs, gapped to 35, also changed fuel filter and rebuilt center carb, Still starts great and idles fine, but as before you take it out for a drive and when car warms up and you get on it!! low and behold, starts popping again let off and it runs fine, put 68 jets in and a 5.5 pv. like i said up until the other day everything was great then like mentioned driving normal to the car show and started popping and now i'm at the end of my knowledge.
Re: Car missing out under load. [Re: mc4406] #792963
09/05/10 10:23 PM
09/05/10 10:23 PM
I feel bad all that changing out & no fix (as of yet). I wonder if the intake bathtub gasket has developed a slight leak on the bottom side. Might richen the pri jets WAY up just for a test & see if that affects it & do you have another ECU in your stash that you could sub in for a day. That way no parts outlay just more time on it.
Re: Car missing out under load. [Re: RapidRobert] #792964
09/05/10 10:35 PM
09/05/10 10:35 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Yes I have another ecu, but it was doing the same thing with the dual point distributor in it, that's why I changed it out with the mopar electronic. Did adjust the fuel level it seemed to help a very little, We did richen it up with the 68 jets, Now it seems to do it more at full throttle before it seemed to go it even driving and just trying to accelerate, I think I'm going to swap the intake and carbs out tomorrow to a sinle 4bbl and see what happens
Re: Car missing out under load. [Re: mc4406] #792965
09/05/10 10:45 PM
09/05/10 10:45 PM
man that is a toughie, all the symptoms ain't adding up, we're missing something.
Re: Car missing out under load. [Re: RapidRobert] #792966
09/05/10 11:02 PM
09/05/10 11:02 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
happened to me , with MSD Distributor,no advance will do that every time. make sure the vacuum advance is working, make sure the vacuum hose is new, make sure where you have the vacuum advance hooked up to is correct and there is no blockage in the carb passage. simple but true
Re: Car missing out under load. [Re: Joesixpack] #792967
09/05/10 11:03 PM
09/05/10 11:03 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
ruptured power valve?
Re: Car missing out under load. [Re: RapidRobert] #792968
09/05/10 11:09 PM
09/05/10 11:09 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
I am leaning towards the intake gasket.
Re: Car missing out under load. [Re: Joesixpack] #792969
09/05/10 11:28 PM
09/05/10 11:28 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
wouldnt a ruptured power vavle just make it run rich? the power vavle is a brand new holley unit and it susposed to be the blowout protection style.
Re: Car missing out under load. [Re: mc4406] #792970
09/05/10 11:36 PM
09/05/10 11:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You need a new magnetic pickup inside your MP dist. Read all of this thread, I'll bet there isn't anything wrong with your carbs. I run a 6 pak also on my 440.
web page
