Re: Msd 6al ?
[Re: Shatar4]
#792937
09/05/10 12:17 AM
09/05/10 12:17 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
For some reason some MSDs make a lot of noise. I can put mine into the passenger compartment while others would drive you crazy if you did.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: Msd 6al ?
[Re: Shatar4]
#792941
09/05/10 05:03 PM
09/05/10 05:03 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I dunno about the whining sound but mine has been making a buzzing sound for 8 years. Its normal I guess...Mine is right above the center console in front of the heater. I had installed the RF Isolator just in case it bled over to the radio but it didnt do anything.
If its not annoying...just crank up your music louder
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
