70 Challenger drip rail seal ?? #792603
09/04/10 01:47 PM
09/04/10 01:47 PM
Ohio
fiddlestix Offline OP
Ohio
I have a 70 Challenger that has the 2 piece drip rails. I was wondering what everyone uses for the foam seals that go under them. I found a place on E-bay that sells this for $25 shipped.
This kit consists of 4 rolls of material for each side of the car
- (2) rolls of 1/8"x7/8" black poly foam to seal between the weatherstrip channel and the roof,
- (2) rolls of 1/16"x3/4" dark gray soft foam with adhesive to seal the weatherstrip channel to the drip rail.
Is this what everyone uses or isn't it necessary?
Are there any better places to buy them?
Could I just use some seam sealer for this area?
As always thanks for any help you can give me.
Re: 70 Challenger drip rail seal ?? [Re: fiddlestix] #792604
09/04/10 04:53 PM
09/04/10 04:53 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I think I bought mine from Board member RestoRick.
Here it is on this website.
http://www.restorick.com/proddetail.asp?prod=RoofRailSeal
65 Barracuda
70 Challenger
Re: 70 Challenger drip rail seal ?? [Re: jrwoodjoe] #792605
09/04/10 05:35 PM
09/04/10 05:35 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Black epoxy would work well or some roofing tar
I've seen the craziest stuff used for gaskets/sealer
Re: 70 Challenger drip rail seal ?? [Re: 71TA] #792606
09/04/10 08:07 PM
09/04/10 08:07 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Got mine from James at the Nat's.(71TA) I'm not sure if it's listed on his site though.
http://www.detroitmuscletechnologies.com/
Re: 70 Challenger drip rail seal ?? [Re: fiddlestix] #792607
09/04/10 10:39 PM
09/04/10 10:39 PM
Pittsburgh, PA
Deuces-Wild Offline
Deuces-Wild  Offline
Pittsburgh, PA
Save some money and use home foam insulation tape. You can find the exact size, thickness, material at lowes/home depo. Works beautifully.
