400 build ?
#792558
09/04/10 01:21 PM
09/04/10 01:21 PM
Posts: 228 northeast texas
strokin73cuda
northeast texas
72 400 block street performance how would you build it and where to get the parts? A friend bought the car we have the engine apart it spun 4 bearings and needs bored of course it has 348 open chambered heads and he wants to do it just a modest powered engine. But while its out and has to be bored anyway I just thought I'd ask the pros'
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: 400 build ?
[Re: strokin73cuda]
#792559
09/04/10 02:23 PM
09/04/10 02:23 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
For about $500, you can fit it with an RB (3.75") crank. May sound like a lot of money for a mild build, but the torque gains will be substantial. Pistons are available off the shelf by many manufacturers, and KB's offerings are as affordable as just about any piston you'll buy for a stock stroke 400. Going this route will turn a mild build into quite a performer. Also, you'll be moving to a forged crank, instead of the cast iron crank you have now, which adds substantial strength and durability.
If going this route is of interest, start doing searches on the Mopar 451.
Re: 400 build ?
[Re: strokin73cuda]
#792562
09/04/10 07:28 PM
09/04/10 07:28 PM
StealthWedge67
Puyallup, WA
Someone here will chime in with a Dallas area machine shop worth checking out. Or, just start calling around to all machine shops, and ask if they do their own crank grinding. Anyone who answers yes to that: ask them if they have experience grinding a Chrysler RB crank to fit into a B block. If they don't know what you're talking about.... move on. You'll find someone that's done it before. It's not hard, you just want someone that understands what youre trying to accomplish.
The 470 version (offset ground rod journals) offers that much more cubes, at a little more money, as it will cost extra to offset grind to a specific radius.
Basically, you're grinding the main journals down and 1/8", and the counterweights down to a 7-1/4" radius.
Re: 400 build ?
[Re: oldtimer5151]
#792564
09/11/10 02:04 PM
09/11/10 02:04 PM
strokin73cuda
northeast texas
Thanks oldtimer, we do not have an extra 440 crank and rods anywhere yet for the build. And this guy is hard to get to spend money wheres the best place to get a reasonably priced stroker kit?
Re: 400 build ?
[Re: strokin73cuda]
#792568
09/13/10 04:12 AM
09/13/10 04:12 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
For a performance build, going with a stroker crank works great and is very cost effective. The issue is that there is not much "off-the-shelf" selection of pistons for the stock stroke 400, so if you want good compression and forged pistons you would need to custom order pistons at $100+ each. Dropping in a 3.75" 440 crank and rods allows you to select from a large selection of affordable off-the-shelf pistons, plus you get the extra 50+ cid. For a bit more money you could even do a 4.15" or 4.25" crank and get 500+ cid, but you will need better than stock rods, but there are some affordable pistons for these combinations too. The KB/ICON forged pistons for any of the 3.75", 3.90",4.15" or 4.25" strokes are $472/set (avaliable flat top or dished) from Hughes or Summit, but they are 0.990" pin, so you would need aftermarket rods. 4.15" Stroker crank (Hughes 21841) $575 Rods (Hughes 10101A) $369 KB/ICON pistons $472 Total $1416. You need to add the cost of rings and bearings plus ballancing, so I guess that is about the same as the $1997 for the 440 source stroker kits?
