Re: Best way to check for header flange leak or valve?
[Re: T/A CARe]
#792468
09/04/10 01:10 PM
09/04/10 01:10 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Last time I had a stumper like that. I ran my shop vac, outside the garage. Fed the hose inside and put it in the tailpipe.
Then crawl under the engine and have a listen.
I had visions of fuel being pulled into the carb and was going to back off the rockers but I got laxy, found the leak and called it done.
[Re: Magnum]
#792469
09/04/10 01:32 PM
09/04/10 01:32 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
put a couple drops of ATF down the carb, if theres a header leak that should confirm it. Or hook up a vacuum gauge...if the needle has a consistent drop in PSI thats usually a sticky/misadjusted valve
[Re: rustbuckett68]
#792473
09/05/10 10:08 AM
09/05/10 10:08 AM
Posts: 2,525 God's Country Maryland
GODSCOUNTRY340
Have a buddy hold their hand over the exhaust pipe (with a rag or welding gloves). An exhaust leak will get louder.
