Popping sound coming from front end? #79194
06/24/08 02:24 PM
06/24/08 02:24 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Two years ago I completely rebuilt the front suspension on my 74 roadrunner and since it has had a popping sound that is somewhere in the frontend. it doesn't do it all the time like a constant everytime the suspension moves but just every once and a while driving on a relativly smooth road it will make that noise. does anyone have suggestions? Everything is new except the torsion bars could that be the problem? Thanks
Re: Popping sound coming from front end? [Re: rck850] #79195
06/24/08 02:38 PM
06/24/08 02:38 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Rubber or poly bushings? I'll bet on poly.
Re: Popping sound coming from front end? [Re: rck850] #79196
06/24/08 02:42 PM
06/24/08 02:42 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Something has to be loose somewhere in the front end for it to be popping.
A buddy of mines car was popping in the r/f when he applied the brakes. He swore he had looked at everything and couldn't find anything. As soon as I jacked it up with the floor jack I could see where the r/s rear upper controll arm bushing sleeve was moving in the UCA.
Re: Popping sound coming from front end? [Re: Pntastar69] #79197
06/24/08 03:01 PM
06/24/08 03:01 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Actually it was a stock rebuild so I went with rubber. Thanks I will check the UCA bushings and also the other bolted connections.
Re: Popping sound coming from front end? [Re: rck850] #79198
06/24/08 03:40 PM
06/24/08 03:40 PM
Check your A-Arm Bolts. I left one loose after my build and it was doing the same thing.
Re: Popping sound coming from front end? [Re: rck850] #79199
06/24/08 04:05 PM
06/24/08 04:05 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
did you change the bushings between the K and the body ?
Re: Popping sound coming from front end? [Re: JohnRR] #79200
06/24/08 04:19 PM
06/24/08 04:19 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Well most of the noise disappeared when I tightened the UCA bolts btw what is the torque spec on the nuts that hold the UCA on the piviot bar? I have never replaced the bushings between the K frame and the front subframe as far as I know they are not even being reproduced. Mine look fine though and have very few dry cracks in them.
Re: Popping sound coming from front end? [Re: rck850] #79201
06/24/08 04:26 PM
06/24/08 04:26 PM
JohnRR Offline
JohnRR  Offline
the fact that they have any dry cracks in them means they need to be replaced , you can get a solid spacer to replace the bushing . have you actually gone to the auto parts store and ASKED for them ? i would be surprised if they aren't still available .
oh and get a factory service manual while you are at it , they are invaluable
Re: Popping sound coming from front end? [Re: JohnRR] #79202
06/24/08 04:34 PM
06/24/08 04:34 PM
scratchnfotraction Offline
look at the strut rods bushing also
Re: Popping sound coming from front end? [Re: scratchnfotraction] #79203
06/24/08 04:46 PM
06/24/08 04:46 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Burred-up or dry torsion bar ends can cause that also, though it's usually more of a 'pop' and a 'ping' sound at the same time.
Rich H.
Esse Quam Videri
Re: Popping sound coming from front end? [Re: ZIPPY] #79204
06/24/08 06:36 PM
06/24/08 06:36 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
try lubricating the pivot point of the strut rod at the lower control arm.
Re: Popping sound coming from front end? [Re: lewtot184] #79205
06/25/08 04:06 AM
06/25/08 04:06 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Thanks for all the help tomorrow I will try what has been said here.
Re: Popping sound coming from front end? [Re: rck850] #79206
06/25/08 11:11 AM
06/25/08 11:11 AM
LA & L.A.
MoparPosterChild Offline
LA & L.A.
Have you noticed if it happens most of the time when you are applying the brakes? Or just regular driving that involves suspension travel?
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
Re: Popping sound coming from front end? [Re: MoparPosterChild] #79207
06/25/08 11:54 AM
06/25/08 11:54 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
regular driving, I don't know if I've ever heard it while applying the brakes
Re: Popping sound coming from front end? [Re: lewtot184] #79208
06/25/08 01:04 PM
06/25/08 01:04 PM
USA
b54406barrel Offline
USA
That's a definite possibility. My blue car started doing that in the mid-70's, especially when driving over a rise & then coming back down. The service manager @ the C-P dealer told me to blow some graphite into that point & that took care of it.
Re: Popping sound coming from front end? [Re: b54406barrel] #79209
06/25/08 01:33 PM
06/25/08 01:33 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
well I laid under the front of the car today and basicly bench pressed the front end up off the suspension and bounced it around, the sound really sounds like its coming from the front torsion bar area. I am still going to lubricate the strut rod mounts but does anyone know what I can do in the torsion bar area? Should I support the car and back off the adjuster and lubricate the area and then run the adjuster back up to set the ride height?
Re: Popping sound coming from front end? [Re: rck850] #79210
06/25/08 01:47 PM
06/25/08 01:47 PM
USA
USA
My '70 service manual doesn't have anything about how to lubricate a torsion bar when it's assembled. Just says to coat both hex ends with lubricant #2525035 after inserting it through rear anchor. That's just regular wheel grease as I recall. I don't think lubricating where the adjustment bolt 'rides' would do much but you could give it a shot.
Re: Popping sound coming from front end? [Re: rck850] #79211
06/25/08 01:49 PM
06/25/08 01:49 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the torsion bars and hex sockets are greased from the factory. if that wasn't done during a rebuild the only way to correct it is taking the bars out and greasing them. i've had popping issues before. in my case it was the the strut rod pivot point at the lower control arm. i didn't lube that point when i rebuilt the front ends on both my coronets. if i had it to do over i would use some type of anti-sieze lube on that pivot point. i've had fairly good luck using Rust-Check spray lube on squeaky-popping front ends.
