power steering to manual steering #792000
09/03/10 11:38 PM
09/03/10 11:38 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
i have a 74 duster 360 that currently has power steering and i want to make it manual steering. is there anything more than just the gear box that needs to be changed? i have a manual steering gear box already just wondering if there was more to it. also i would like elimanate the brake booster what all is required to do so. thanks everyone.
Re: power steering to manual steering [Re: cole63b] #792001
09/04/10 12:05 AM
09/04/10 12:05 AM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
You will need a Manual Steering Column or an Adapter. The Power Box is longer than a Manual Box and the shaft coupler is also different.
Re: power steering to manual steering [Re: joewhite440] #792002
09/04/10 11:48 AM
09/04/10 11:48 AM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
ok thanks thats what i was thinking but was unsure about it.
Re: power steering to manual steering [Re: cole63b] #792003
09/04/10 01:14 PM
09/04/10 01:14 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Or cut and splice the shaft 3" longer. ( I think it's 3"). Make sure you index it.
Re: power steering to manual steering [Re: cole63b] #792004
09/04/10 02:08 PM
09/04/10 02:08 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
There are 2 adapters, OEM used on Dodge vans and one from Firm Feel. Easiest way is to use the adapter from Firm Feel. It lets you use the power shaft coupler where the OEM van adapter reqires the use of a manual shaft coupler.
Cheapest way is weld in a 3" extension as posted above.
Also check the worm shaft size. Make sure the pitman arm off your power box will change over to the manual box you have, if not, you'll need a '73-up Abody manual steering pitman arm.
