Re: more ignition questions ???
[Re: plymguy]
#791829
09/03/10 11:13 PM
09/03/10 11:13 PM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi had same problem on a car once , turned out to be a pickup coil in dist . would shut down and after cranking would restart and run fine agin . sometimes just took longer than normal to start cold .
[Re: plymguy]
#791832
09/04/10 01:11 AM
09/04/10 01:11 AM
RapidRobert
Has it been doing this since the conversion or recently? I would check the ECU ground and might (re)check the bulkhead. I use a small metal bristle brush on the male ones and a new brass male terminal (NAPA has em) to clean the female ones. Yes jump directly from starter relay to the blue loop on that end of the 4 terminal ballast & see if it fires and when it wont start if you have a helper to crank it w the key while you check voltages at the ballast/coil/ecu and a 5 pin ecu needs voltage at 2 pins in start (ign2)
