Re: B&M shfter cable
[Re: howard toland]
#79173
06/24/08 05:11 PM
06/24/08 05:11 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
are you burning them up because the headers are open? try some header extensions or run them through something to shield it. do you have good grounds? many a cable has been burned because the engine/trans are not grounded properly. good luck..
I am truckless..
[Re: howard toland]
#79176
06/24/08 07:26 PM
06/24/08 07:26 PM
Posts: 25,886 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Imperial Services claims to have wire-wound shift cables that won't melt.
[Re: John_Kunkel]
#79177
06/24/08 07:51 PM
06/24/08 07:51 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
mine runs from the floor, hugs the transmission forward, then I routed it between the starter & the block to keep it away from the headers. Zip tied it to a tab I installed at one of the inspection sheild bolts. I've always found them to be pretty resilient. Only thing you can't do with one is let it lay directly on a header tube.
[Re: howard toland]
#79179
06/24/08 08:27 PM
06/24/08 08:27 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I have a B&M Quicksilver that I modified to be stock appearing. The included cable is routed around my downpipe (I am running manifolds) and is about 1.5" away but I wrapped it with some 3/8 fuel line and its been happy so far.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#79180
06/24/08 11:48 PM
06/24/08 11:48 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I had the same issues with the cable on my pro ratchet. I now have a 4' cable and while it's a tight fit it doesn't touch my supercomp headers. I also run it through a thermal sleeve for protection.
I've also heard the standard duty cables are more flexible than the heavy duty ones like the ones that come with the shifters. May be worth looking into.
