318 mag A/C and Power steering on a big block #79155
06/24/08 12:47 PM
06/24/08 12:47 PM
Cooperstown, NY
jrlegacy23 Offline OP
Cooperstown, NY
I am doing a big block swap on a 318 dakota. It has A/C and power steering (rack and pinion). Is there any place that makes adapters to put these units on my big block?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: 318 mag A/C and Power steering on a big block [Re: jrlegacy23] #79156
06/24/08 03:21 PM
06/24/08 03:21 PM
Andrewh Online content
Andrewh  Online Content
Jerry here uses some of those parts in a serpentine belt kit for bb.
Re: 318 mag A/C and Power steering on a big block [Re: Andrewh] #79157
06/24/08 05:19 PM
06/24/08 05:19 PM
Cooperstown, NY
Cooperstown, NY
How can I get in contact with Jerry?
Re: 318 mag A/C and Power steering on a big block [Re: jrlegacy23] #79158
06/24/08 07:54 PM
06/24/08 07:54 PM
Re: 318 mag A/C and Power steering on a big block [Re: Andrewh] #79159
06/26/08 12:11 PM
06/26/08 12:11 PM
Cooperstown, NY
Cooperstown, NY
Thanks, I just contacted him, Jerry has a great looking product, but $650 was a little deep for my pockets. Anyone know of a cheaper place?
Re: 318 mag A/C and Power steering on a big block [Re: jrlegacy23] #79160
06/26/08 01:40 PM
06/26/08 01:40 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
short of making your own brackets there isn't anything cheaper on the market. give me a call back we can probably work something out.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 318 mag A/C and Power steering on a big block [Re: Jerry] #79161
06/26/08 07:45 PM
06/26/08 07:45 PM
Cooperstown, NY
Cooperstown, NY
Thanks Jerry, I will call you. I have a few other parts I have to get to finish the motor first. Then I will contact you. Thanks again.
Re: 318 mag A/C and Power steering on a big block [Re: jrlegacy23] #79162
06/27/08 02:09 AM
06/27/08 02:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Jerry makes some good stuff. 650 though? glad I got mine when I did! (what's it been...2 years ago now?) are you making them from all CNC now, or still using modified magnum brackets?
Here's a picture of the kit I bought from him, it runs a stock magnum alternator and A/C pump, a Jeep PS pump, a GM belt tensioner, and adapters to put magnum pulleys on the water pump and crank.
I like it! (Mine's even on a Dakota too!)
The only other options that I know of are A) the cheap kit that simply replaces your pulleys from V-belt to serptentine, and still uses 2 or 3 different belts like the old school V-belt systems.
or B) the 2500 polished chrome version that is 100% custom and all aftermarket.
**Photobucket sucks**
Re: 318 mag A/C and Power steering on a big block [Re: 70Cuda383] #79163
06/28/08 01:37 PM
06/28/08 01:37 PM
Cooperstown, NY
Cooperstown, NY
I like your dakota with the big block. It looks like a nice clean install. What headers did you use? I found one guy that would make custom ones, but wanted $1200.
