Re: Stock fuel line routing for `70 & later Holley 4bbl?
[Re: SuperRob]
#791353
09/03/10 11:01 AM
09/03/10 11:01 AM
Posts: 9,838 Detroit, Michigan, USA!
peelerboy
Very cool, Rob! Thanks! That actually helps quite a bit. I can at least tell (now) the general routing of the line comes up between the alternator and the water pump, then cuts over sorta' beneath the front of the distrib before bending car-rearward to the carb! Ideally, I'd really love to see a pic with the air cleaner assembly off, but this will get me where I need to go even if I can't find any other pix! Thanks again! Dale
[Re: peelerboy]
#791354
09/03/10 12:22 PM
09/03/10 12:22 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Thanks again!
Dale
v You can see that ???
[Re: JohnRR]
#791355
09/03/10 12:45 PM
09/03/10 12:45 PM
peelerboy
Heck yes I can! And you know WHY I'm seeking this info, don't you John? It's so I can take the Challenger to the PSMCDR's on the 17th and the 18th! Are you gonna' bring the mighty Dart? We'd probably get paired up if you did! That'd be cool... two 383-4spd cars battling it out. Dale
[Re: peelerboy]
#791357
09/07/10 01:06 PM
09/07/10 01:06 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Here's a picture of the carb/fuel line contact area. Thanks fo the guys over at ICCA..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
