69 RR/GTX Engine Wire Harness Available? #791242
09/02/10 10:12 PM
09/02/10 10:12 PM
dart1962_440 Offline OP
Anyone know where to get one? Are they re-popped?
Pat
Re: 69 RR/GTX Engine Wire Harness Available? [Re: dart1962_440] #791243
09/02/10 10:25 PM
09/02/10 10:25 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Year One. Several configurations to chose from. I have used them, they work great with accurate connections and generous amount of wire.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: 69 RR/GTX Engine Wire Harness Available? [Re: Kowal] #791244
09/03/10 05:31 PM
09/03/10 05:31 PM
Thanks for the reply on Year One having the harnesses. Now I just have to figure out a discount code...
Re: 69 RR/GTX Engine Wire Harness Available? [Re: dart1962_440] #791245
09/03/10 06:29 PM
09/03/10 06:29 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
BUY09... wil get you 20%
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 69 RR/GTX Engine Wire Harness Available? [Re: JMCFAN] #791246
09/03/10 08:36 PM
09/03/10 08:36 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
If your 69 is going to have a Mopar electronic ignition, do not buy the modified harness that Year One has that it says is for using electronic ignition. That harness is set up for the wrong ballast resistor and voltage regulator for a '69. It is easier to buy the stock harness from YO and then modify it with the Mopar elec ignition kit.
Re: 69 RR/GTX Engine Wire Harness Available? [Re: Kowal] #791247
09/04/10 08:19 AM
09/04/10 08:19 AM
I think the modified one will work for me. I have electronic and the car was converted to the 70 v-reg & alternator set up.
