If your 69 is going to have a Mopar electronic ignition, do not buy the modified harness that Year One has that it says is for using electronic ignition. That harness is set up for the wrong ballast resistor and voltage regulator for a '69. It is easier to buy the stock harness from YO and then modify it with the Mopar elec ignition kit.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at
www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
