late model alternator swap #791033
09/02/10 08:37 PM
09/02/10 08:37 PM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
I know there is a template for the late model swap, but I need some up close install pics, no matter how I play it, the late model nippondenso alternator doesn't line up on the water pump pulley....can anybody help with some pics?
Re: late model alternator swap [Re: '84 D150 Shorty] #791034
09/02/10 08:55 PM
09/02/10 08:55 PM
scratchnfotraction Offline
got them on my BB
try flipping it over and use the single ear as the pivot point
thats how i did the one on the 440 with the MH non a/c brackets
fine tuned some spacers and lined the double groove right up
moved the batt wire out away from the head,so no grinding like some of the older posts talked about
i did add a couple inches to the adjuster swing arm with a bend so it would not hit the alt case
let me look I have some pics on a post and pm that was sent to me for a sb IIRC
goody had a good write up on his on the sb,think he gave me the tip to flip it over
the archives have a template you print out for a sb also
i got a couple ruff cut ones already done,need a good clean up and some finish grinding,want one?
Re: late model alternator swap [Re: scratchnfotraction] #791035
09/02/10 09:05 PM
09/02/10 09:05 PM
TN
Pickup Man
Pickup Man
TN
I would love one!
Re: late model alternator swap [Re: '84 D150 Shorty] #791036
09/02/10 09:10 PM
09/02/10 09:10 PM
you got it
i bumped alt pic post back up
Re: late model alternator swap [Re: scratchnfotraction] #791037
09/03/10 11:01 PM
09/03/10 11:01 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Where's the pic's of the alternater install?
Re: late model alternator swap [Re: gtx69] #791038
09/03/10 11:08 PM
09/03/10 11:08 PM
look for the post I bumped back up
by..furrystump..mini alt pictures for scratchin
shows the spacers he used with stock brackets on the sb with toyo alt
Re: late model alternator swap [Re: scratchnfotraction] #791039
09/03/10 11:45 PM
09/03/10 11:45 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Looking for pictures for bb
Re: late model alternator swap [Re: gtx69] #791040
09/04/10 09:27 AM
09/04/10 09:27 AM
here are some of the one on my BB
if you need a shot of anything else of diff angle I can snap a couple more for you
Re: late model alternator swap [Re: scratchnfotraction] #791041
09/04/10 09:28 AM
09/04/10 09:28 AM
another
Re: late model alternator swap [Re: scratchnfotraction] #791042
09/04/10 09:29 AM
09/04/10 09:29 AM
last one for now
Re: late model alternator swap [Re: scratchnfotraction] #791043
09/05/10 08:28 PM
09/05/10 08:28 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
http://www.cuda-challenger.com/cc/index.php?topic=67747.msg695477#msg695477
same info
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: late model alternator swap [Re: GoodysGotaCuda] #791044
10/07/10 08:20 PM
10/07/10 08:20 PM
Sarasota, Fl
siggie30 Offline
siggie30  Offline
Sarasota, Fl
Picture taken from :http://www.cuda-challenger.com/cc/index.php?topic=67747.msg695477#msg695477
What exactly is the black housing for? I have the same setup, and am trying to clean up my wiring. Is that the regulator? Or just fuseable links?
I don't even have 1/2 lift, but the other 1/2 is nitroused.
