Help!!!! Tough one #790998
09/02/10 07:38 PM
09/02/10 07:38 PM
Brea, Ca
Dart Racer Offline OP
Brea, Ca
My 68 Charger 440 99% stock motor will just shut off like I turned the key off at random times. It will then restart within 5 minutes and then run for several trips/days. I checked all the harnesses, coil, ignition switch, and can find nothing wrong except for the coil was leaking so I installed a new one. The car then ran for a couple of days and then today, boom, it quit again. The problem is not heat related, has quit cold and hot.
Any ideas anyone?
Re: Help!!!! Tough one [Re: Dart Racer] #790999
09/02/10 07:46 PM
09/02/10 07:46 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I'd say start by checking the ballast resistor.
I'd also check the voltage on the output side of the resistor.
Re: Help!!!! Tough one [Re: Dart Racer] #791000
09/02/10 07:48 PM
09/02/10 07:48 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Dying ballast resistor maybe it's cracked?
Re: Help!!!! Tough one [Re: moparpollack] #791001
09/02/10 08:29 PM
09/02/10 08:29 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
I know you checked the harnesses but some people have had that same mystery problem because the main bulkhead at the firewall was either loose or not making good contact with the connections.
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Help!!!! Tough one [Re: Dart Racer] #791002
09/02/10 08:36 PM
09/02/10 08:36 PM
99% stock motor. Any ideas anyone?
Assuming OE ballast/points etc. Make up a jumper wire and "T" it to the upstream side of the ballast and for a # of days when you head out connect the other end to either the alt "batt" stud or the starter relay "batt" stud & when you get home disconnect it. If it still acts up that'll tell you it's a component prob as opposed to a part time "open" wiring prob. EDIT What Hitit said, seperate the bulkheads & clean the brass terminals. Small metal bristle brush on the male ones and a spare male one to clean the female ones. Might get an easy fix to this
Re: Help!!!! Tough one [Re: RapidRobert] #791003
09/02/10 09:40 PM
09/02/10 09:40 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Hows the fuel look. You might have some water in the tank and when it hits the engine they will not run on water, also crud in the tank can do the same thing, cuttin off fuel to the engine.
Re: Help!!!! Tough one [Re: Dart Racer] #791004
09/02/10 11:29 PM
09/02/10 11:29 PM
Ma, USA North of Boston
74SatSundance Offline
Happened to me last year.
360 with the FBO setup (box/coil/resistor and distributor set-up)
It was the CPU box (that was the only thing I changed). I changed it with another one they sent and it didn't happen again (now I carry a couple extras, different brands). Mine happened a bit more frequently, usually quit once every other trip on the road.
Very scary thing when it happens depending on where you are, and would take anywhere from several seconds to a few minutes to get it to restart.
Re: Help!!!! Tough one [Re: 74SatSundance] #791005
09/03/10 01:15 AM
09/03/10 01:15 AM
Brea, Ca
Brea, Ca
Thanks for all the suggestions!!!!!
I'll start further testing. Maybe it's getting closer to fully failing as today after this post it died 3 times on three real short trips. Always started back up after a couple of minutes. two of the times car was stopped, other time I was cruising at around 25.
Things that are flat broke are easier to fix, that's for sure!
I'm going to grab a electronic box on the way in to the shop tomorrow.
Re: Help!!!! Tough one [Re: Dart Racer] #791006
09/03/10 01:27 AM
09/03/10 01:27 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Sounds like a classic bad wire connection. Could take a while to find. Good luck
Re: Help!!!! Tough one [Re: Cudajon] #791007
09/03/10 12:37 PM
09/03/10 12:37 PM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
A clear plastic fuel filter makes it real easy to determine if this is the problem.
