Ford sb headers on a 318 poly? #790799
09/02/10 03:48 PM
09/02/10 03:48 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
After some research, I've noticed that if full flanged Ford small block headers are finely centered against a 318 poly head, the two inside runners will be too wide by .040" each, forcing the two outside runners to be off by .080". So if a section .080" wide is cut from the center of the flange, and then the flange pushed back together and welded, the two inside runners will be a match leaving the two outside runners just .040" off each, which could be fixed with mild runner matching.
Then, if the flange is wide enough, or extra material is welded on, the flange could be drilled for the mopar bolt pattern (which is different).
If one already has the ford headers, and clearance (starter, steering, etc.) is not a problem, it seems like a cheap way to get headers for the 318 poly. Anyone disagree, or has anyone tried this? Thanks!
Re: Ford sb headers on a 318 poly? [Re: polkat] #790800
09/02/10 04:41 PM
09/02/10 04:41 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
Hmmmm. I was gonna try a set of 351-400 truck headers on my 66 d100. This could be another option also. Hopefully someone else will chime in.
This space available for rent
Re: Ford sb headers on a 318 poly? [Re: cptn60] #790801
09/02/10 06:02 PM
09/02/10 06:02 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
how about either trying to purchase 318 poly header flanges (maybe from headers by ed?) or having some laser cut, cut the flanges off ford headers, and weld the new ones on?
of course, who knows if you'll have clearance issues with the torsion bars or steering box.....
2017 Grand Cherokee Overland
Re: Ford sb headers on a 318 poly? [Re: cptn60] #790802
09/02/10 06:02 PM
09/02/10 06:02 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I think it might be a viable possibility. Part of the problem might be any difference in the different head port sizes. If, for example, the header tubes are wider on sb ford headers, it might block being able to drill bolt holes in the flange for the poly pattern. I'm going to try it, but I agree that others might have better info, particularly those who have already tried it.
One post on another site suggested welding poly flanges on the ford flange and drilling through the poly flange, but that seems like extra and unneccessary work to me.
Most sites I have searched talk about adapting ford headers to the poly, but I have yet to find someone who has!
Re: Ford sb headers on a 318 poly? [Re: patrick] #790803
09/02/10 10:39 PM
09/02/10 10:39 PM
cptn60 Offline
cptn60  Offline
Possibly on a car you could have interference. On my truck there is plenty of room, maybe a set of moistbang 5.0's could work. Yeah there would be a port mismatch, but it may be an improvement. the 2barrel C/M headers I own have bigger ports than an A motor
Re: Ford sb headers on a 318 poly? [Re: cptn60] #790804
09/03/10 11:59 AM
09/03/10 11:59 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i was going to do this many years ago. as far as i remember it was going to work. i did but some poly header flanges off of ebay, but never finished the project.
Re: Ford sb headers on a 318 poly? [Re: 65rbdodge] #790805
09/03/10 09:10 PM
09/03/10 09:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
On a sorta related note, many years ago I saw a FWD Daytona converted to RWD with an LA motor in it. The owner used a SBC header with an LA flange welded on to fit the chassis. I have been looking at SBC headers that might be adaptable to my early A, way cheaper than TTI.
Don't be the exception.
Re: Ford sb headers on a 318 poly? [Re: polkat] #790806
09/03/10 11:46 PM
09/03/10 11:46 PM
crlush Offline
crlush  Offline
that would be great if they fit tti headers are nice but there worth more than the engine,hehe.
Re: Ford sb headers on a 318 poly? [Re: polkat] #790807
09/04/10 07:54 AM
09/04/10 07:54 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
I bought a set last year at the NATS for $225. They're custom built and very nice. The look like the Spitfire headers in design. I saw several sets on e-bay for less after I bought these but not since.
Re: Ford sb headers on a 318 poly? [Re: wedgeheaded] #790808
09/04/10 11:07 PM
09/04/10 11:07 PM
Here's a set of 318 poly headers from the 50's (note the generator bracket on the passenger header). Ballenger brand; don't think they are still around
