vacuum with trans locking dipstick #790633
09/02/10 08:19 AM
09/02/10 08:19 AM
St. Louis Mo.
10 o to go Offline OP
"Happy Don"
"Happy Don"
St. Louis Mo.
Ok this year we had to put on the locking dipstick on .
what i found is that when you change the fluid the fluid doesn't just drain out its air locked .
When i pull the dipstick out it drains freely .
I run a Tbrake so we do have a vent .
Wondered if my sluggish trans was caused by this vacuum.
I pulled the trans out to put a fresh one in .
I,m drilling a small hole below lock rubber seal .
Don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: vacuum with trans locking dipstick [Re: 10 o to go] #790634
09/02/10 09:50 AM
09/02/10 09:50 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Perhaps your vent is either not big enough or clogged.
Re: vacuum with trans locking dipstick [Re: WILD BILL] #790635
09/02/10 11:59 AM
09/02/10 11:59 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
would have been my first check
home of the
Sox and Martin Hemi Duster
Re: vacuum with trans locking dipstick [Re: 10 o to go] #790636
09/02/10 12:05 PM
09/02/10 12:05 PM
NY usa
540challenger Offline
NY usa
Don
One problem with drilling a hole in the dip stick tube is IF they find it i don't think tech would like that it kind of defeats the reason for having a locking dipstick to begin with.
Re: vacuum with trans locking dipstick [Re: HEMIFRED] #790637
09/02/10 12:08 PM
09/02/10 12:08 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Some vents do not allow enough air flow to allow the fluid to drain freely.Think of it as a drinking straw.Place it in a glass of water and place your thumb over the end,remove the straw from the glass with your thumb still covering the end,the water remains in the straw,slightly uncover the end of the straw and the water will trick out,remove your thumb and the straw will empty instantly.Just remove your dipstick when draining the trans.
