sb edelbrock head ? #79039
06/24/08 07:06 AM
06/24/08 07:06 AM
USA
K
krw71ragtop Offline OP
K
USA
what is the torque specs for edelbrock heads with ARP bolts ? The ARP bolt package says 75 ft lbs with assembly lube. Edelbrock instructions say 45-65-95.
Re: sb edelbrock head ? [Re: krw71ragtop] #79040
06/24/08 10:55 AM
06/24/08 10:55 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
my addvice is to use the grade 8 hardware and follow edelbrock specs.
arp is fine, the strech is different to keep it tight. i would contact both companies and compare notes. investigate discrepancies.
Re: sb edelbrock head ? [Re: krw71ragtop] #79041
06/24/08 02:10 PM
06/24/08 02:10 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Call ARP if you are unsure. This is more about bolt characteristics than the head itself.
Do the instructions require a different torque spec for another style head, aluminum vs. iron? If not, I'd tend to lean towards the ARP spec as they designed, manufactured and tested the product. Edelbrock has no idea regarding your ARP bolt characteristics.
and for the "But you ain't got no legs, Lieutenant Dan." crowd. He's already identified a discrepancy. Might that be the reason for the question.
Re: sb edelbrock head ? [Re: RobX4406] #79042
06/24/08 02:46 PM
06/24/08 02:46 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have used the above eddie specs before, they look right on.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: sb edelbrock head ? [Re: RobX4406] #79043
06/24/08 07:58 PM
06/24/08 07:58 PM
USA
K
K
USA
ARP indtructions:
Preload (torque recommendations:
[A] Torque values are based on 75% of the fasteners yeild strenght. Use the manufacturers torque sequence but do not use the engine manufacturers torque specs. Torque the bolts to 85 ft lbs for ARP MOLY ASSEMBLY Lubricant (or ARP thread sealer) or torque to 130 ft lbs with 30wt motor oil.
B] Due to the heat expansion rate of ALUMINUM, it is recommended that the torque should be 75 ft lbs with ARP moly assembly lubricant (or arp thread sealer).
I e-mailed Edelbrock this morning but havent gotton a response.
Re: sb edelbrock head ? [Re: krw71ragtop] #79044
06/24/08 09:39 PM
06/24/08 09:39 PM
I torqued mine w/arp lube to 75lb, that was 4 years ago. So far so good.
Re: sb edelbrock head ? #79045
06/24/08 10:16 PM
06/24/08 10:16 PM
USA
K
K
USA
Well that gives me some verifivation that 75 ft lbs will work.
Thanks Anyone else do 75 ft lbs ?
